Kevin,
Great advice. Now give us the mixing ratios!
Thanks,
John
No it is a
SECRET! This is my super secret magic elixir recipe that makes my blades so indestructible! Along with the contracts I have with the U.S. Military (and some other countries) I have at least 24 patents in the works on it. So no ratios as I have already given too much by mentioning the obvious ingredients. Also be careful how you reply as I have applied for a copyright on the words elixir water, and just to be safe patent.
Actually John, as per the other replies the ratios are not really relevant as long as you get a liquid that will carry away the particles and not tear up the steel or the abrasives. I use this mostly because I was too cheap and lazy to go to the store and buy 409. I mix it a little different every time depending on what I have on hand, and sometimes omit ingredients. Heck I don't even know if anything beyond the soap does anything, but here is my reasoning-
The soap is to help avoid corrosion and make the water "wetter".
The TSP is for much the same but also to help cleanse the steel for things like etching as well as an easy spray to clean off FeCl after the etch.
The alcohol is to keep things from staying wet all darned day and to help cleanse due to the solvent action.
However it can also effect the amount of rubbing you can do between spritzing and how the black slurry stays on the blade, today I added a little too much and found things drying out and getting pasty a little too quickly- so I added more water. But in the right amount it seems to keep things from turning orange if you get distracted.
I also use this mix for a coolant when drilling or milling tough items so my hodge podge of ingredients makes it a more versatile multipurpose spray bottle to have sitting around.
