Not just easy to sharpen, but lightning fast to sharpen!
Acute point makes a great splinter picker--or any other fine, detail work.
As mentioned, Wharncliffes are great for opening up that diabolical clam-shell packaging.
Just got a Schatt&Morgan series XVIII Barehead English Jack.This has a MONSTER Sheepsfoot as the main blade(large pen secondary).
I'm very struck on the look of these blades(Wharncliffe,Sheep&Lambfoot)as well as their uses in precision work. Hardly used this one as only had it a day, but it slices a rich fruit cake nice and thick!
Haven't seen much negative.
338375,
Here is a picture of the Schatt & Morgan knife I believe Willgoy has referenced:
I got picture from a web seller's site. Hope this helps. :thumbup:
338375 Been telling myself to master my digi camera and read a tutorial(if it exists)on putting pix on this site.....
Best I can do for you now is check dealers' sites for S&M series XVIII 2008 Barehead English Jack. Model No. 042429. In comes in wonderful brown 'worm grooved' bone.
4.5" closed, main blade 3.5" pen 2.5" Good snap so watch your fingers...I got it from the Bay but I think dealers such as Sooner State or Collector Knives etc will have them.
And yes, a rich loaf shaped fruit cake got some nice slices cut by this, then I trimmed up a plum tree.
Welllll....
I was not gonna comment, since you were asking for reasons to try one, not reasons not to try one...
But, I don't like them. They are fine in 1/2" or shorter blades for whittling, fabulous in fact. But for EDC I find them almost useless.
My main peeve is if I need to cut down through something against a surface, there is no room to grip the handle, and still cut with more than the tip of the knife... Hand hits surface, long before anything other than the blade tip contacts it. No slicing against a cutting board. A wharnie / sheepsfoot is great for push cuts, but I never need a push cut.
I tend to slice/draw cut against the bellie of a blade even in 'mid air' non surface/backed cutting as well. So; I guess its just that slicing cuts are extremely hard to do with one, and I cut in that way.
So, I'd say that if you tend to use the forward 1/3 or 1/2 of a clip point or drop point a lot, you might net get along with a straight edge.
By all means, get one, use it and find out whether its for you or not... If ya don't try, then ya don't know! :thumbup:
G.
Pull cut with a wharnie blade on a cutting board
Very lightly, place tip of blade on board.
Hold the knife at an angle that is comfortable to you (try 22 deg)
Pull back the knife across the object to be cut
This cut can be used for halving big sheets of paper, slicing vegetables, or trimming leather
A good technique! :thumbup::thumbup:
It was never satisfactory for me- just seemed too much cutting with just the tip or say, the tips 3/8" or 1/2", even in thicker materials, it didn't "feel" right.
By all means, if it works for you, then :thumbup:
G.
