allenC said:Now we're getting somewhere.
So, what exactly were you doing with the knives?
Allen.
Tony Turner said:Thanx Skammer, that was an example I was looking for, now was that so hard![]()
Someone point me exactly to the great owners manual of knives where it says it should only be used for cutting.![]()
Needless to say, I have snapped a few folders over the years but I don't abuse folders anymore becasue I assume they will break and have no reason to believe this will change. It just not in a folder to withstand prying.
Ebbtide said:I guess you have to read between the lines of the great owner's manual of knives.
:yawn:
Cliff Stamp said:Some folding knives are made to pry, Striders and ER being obvious ones. If a folder is made "just for cutting" the blade is 1/16", full hollow ground on full hard steel. When you move towards thicker stock, heavier grinds, softer steel, this is done to allow the blade to move beyond being a pure cutting tool.
-Cliff
skammer said:So can I pry it like a good user fixed blade and not break these super folders?![]()
Skam
Razorback - Knives said:Here's a question to ponder, what is the optimal blade thickness and grind type for the types of knife use skammer described? Or would the heat treat play a part in the breakage and bending?
Scott
Thomas Linton said:Hey, you've "folded" some "good" fixed-blades, so why not?![]()
(He already answered your question: "fails.")
Thanksskammer said:I would think there is a host of issues in the durability/ utility outcome, like steel type, heat treat, grind, thickness, geometry etc......
Skam
Tony Turner said:...list the task you are doing
Razorback - Knives said:...what is the optimal blade thickness and grind type for the types of knife use skammer described?
...would the heat treat play a part in the breakage and bending?
Tony Turner said:Here is a great oportunity for you to list what other knives you have seen other people break, trying to duplicate what you do with your knives for survival situations. Please list the task you are doing, and why. I am just really curious.
thanx
