Coming from the Corian counter top industry, I can tell you that the appropriate pressure for expoxy without "starving the bond" is always guaranteed with Pony (or cheaper brand) 2" spring clamps. If you cant sandblast your blade (scale area), I have, from time to time used a cutting wheel on a dremel/foredom to "scuff" the blade. Cleaning prep is also underrated. You have to make sure that all lubricants (cutting fluid, machine oil, etc) is removed. I only use denatured alcohol, as some of the other solvents leave a residue, which means degradation of the epoxy bond. Then, do not touch the cleaned area with bare hands (natural oils in hands). When doing the prep and gluing procedures, I wear a pair of powder free latex exam gloves. Keeps the hands clean of epoxy and keeps you from depositing oil from the hands. 30 minute plus epoxy is the only thing to use then forget about the knife for the next 24 hours. Since epoxy is a chemical reaction, I "accelerate" or enhance the cure by placeing the glued up knife in a second hand dehydrator over night.
