- Nov 28, 2012
Sharpmaker ceramic rods tend to easily cause burrs on Case's stainless when used with anything other than light pressure. It is somewhat ductile and so tends to smear more than abrade with the ceramics for some reason. Stropping helps out with the Tru-sharp for me.
You also don't want to spend too much time on that steel or you end up just flopping the burr back and forth, or removing and recreating constantly.
I used to spend a lot of time with a Sharpmaker myself on Case knives. Finally taught myself to freehand and I find that it works much better. Best result for me is from a Fine Norton India then soft/hard Arkansas then strop. Not much time on any stone. If I need to get the initial bevel set, then Coarse India. You can raise a full length burr on a coarse India on that steel in just a few passes.
I try to deburr on the coarsest stone in whatever progression I am using so that all I am doing on the finer stones is polishing/refining the already sharp edge. That's why I don't like to spend much time on the finer stones - I don't want to create a new burr, though I do watch for it and try to keep it to a minimum. No need for a fresh burr at each level - you already apexed it on the coarsest stone if you did it right.
Real world, I am MUCH lazier than what I just laid out. I have a Norton Economy SiC combo stone in my desk. If I have a knife where the edge is a little dull - a few light passes on the fine side (so about 320 grit) then straight to strop, and back in my pocket. I only do that whole shtick if it's a new knife that needs the initial edge set.
Case's CV steel is easier to sharpen because the burr is not as tenacious. The SS is not much harder to sharpen once you get used to it.
