what are some ways to compensate for expansion/contraction of stabilized wood.
As I understand it all expands and contracts. The issue as I understand is, the stabilized woods and resin shifts at a different rate than glue, liners and metal bolsters.
Do you have some design work around and ideas to help prevent or to better cope with distortion?
The best I've found is a hidden tang knife, with fiber spacers between it and the guard. On a full tang knife, a mechanical lock of some sort, ie peening the pins or Loveless style bolts. And I like to use fiber spacer between the tang and scales. On full tang knives I also skeletonize the tang and generally glue one side at the time or at least mark out and drill and dremel blind holes for a thicker epoxy area. Also like to hollow grind the full tang to make for a larger epoxy area. Still don't rely on epoxy alone, I almost always peen or use bolts to fasten the scales on so that epoxy is more of a seal than anything.
I've heard some people complain about fiber spacer material moving, but that's one of the reasons I use it. It gives and acts like a shock absorber to the handle material.
