52100 isn't difficult to heat treat. It depends on the condition the steel arrives in. Aldo's is course spheroidized, and needs normalization and thermal cycling. It's super easy if you have a kiln. If you get stock from AKS, you can stock remove and austenitize without cycling, as the steel is in a more heat treat friendly condition. If you forge, you need to normalize and cycle anyway, so normalizing is a normal part of the process. With Aldo's steel, I normalize and cycle all the carbon steels (except 15n20- my testing showed no difference) Not a biggie, it just lets me get consistent results.
I think there are a lot of people that would disagree that getting the best properties from 52100 via a straightforward heat treat really works. With an extra .1% carbon, getting that carbon where it should be takes more than just normalizing. It requires thermal cycling as well to get the carbon to the right places without causes grain growth at the same time.
It is easy to make an okay blade from 52100 without thermal cycling, but you're really not getting the most out of the alloy, and it will have a bunch of either pearlite or RA in it preventing the performance of the steel from being as good as a lower carbon alloy that put the carbon where it belongs.
I've made many great blades out of 52100. There is no magic, understand the steel and metallurgy, and it's straightforward.
WHAT 52100 is not magic, that is why you edge pack it that is where the magic is.
I don't know your process - whether you were forging or grinding and what state the steel started in. But if you went up to normalizing temps but never did any thermal cycling around quench temps, then it is unlikely 52100 got as hard as it can or should.
I have a great knife I made a long time ago by heating 1095 up over magnetic and quenching in water. It is very hard and holds an edge, but I realize that without at least a soak the carbon did not get where it should be, and what I made wasn't much different than if I had used 1075.
No, edge packing only works if you have magnets on your anvil. That's where the magic is, because no one knows how magnets work. They just do.
