It's not so much a matter of how they're made as much as the material that comprises the product. Both aluminum oxide and silicon carbide are inherently ceramics, in that they are "non-metallic solid material comprising an inorganic compound of metal, non-metal or metalloid atoms primarily held in ionic and covalent bonds."
But, as noted prior, in the knife world we usually mean it to indicate a sintered ceramic, aka "technical ceramic".
"A ceramic is an inorganic non-metallic solid made up of either metal or non-metal compounds that have been shaped and then hardened by heating to high temperatures."
'Natural' stones:
Usually implies so-called 'Arkansas' stones in the U.S. They are composed of a natural mineral called 'novaculite' (silica-based). Not very hard (Knoop hardness = ~ 825 or so). These only work well with simple carbon steels and low-alloy stainless, like 1095, CV, 420HC, 440A, etc. Elsewhere in the world, other natural stone types exist. Most all natural stones won't be much harder (abrasive-wise) than the Arkansas stones. All are limited to relatively simple steels without much hard carbide content.
Man-made or 'synthetic' stones / other abrasives:
Aluminum oxide (Al2O3) -> these would include Norton's 'India' stones and many other hardware store-type oilstones, as well as many man-made waterstones. Knoop hardness around ~ 2100; suitable for a lot of middle-of-the-road steels with up to moderate wear-resistance (from something like 440C, 154CM, VG-10 up to something like D2, ZDP-189). Doesn't work quite as well with steels containing more than ~ 3% vanadium, the carbides of which are harder than the abrasive (Knoop hardness for vanadium carbide = ~ 2800 or so). Aluminum oxide is heavily used in many polishing applications (pastes, like Simichrome polish, Flitz, Mother's Mag wheel polish, etc). In such form, these also work well as stropping compounds on the same range of steels noted above. (Edited to add: ) Most 'ceramic' hones used in sharpening are also made with aluminum oxide (usually referred to as 'alumina ceramic').
Silicon carbide (SiC) -> Norton's 'Crystolon' is likely the best-known, but also the old-school 'Carborundum' brand as well. Some hardware store stones will also be in SiC (some ACE branded stones, Gator & others), as with the aluminum oxide oilstones. Knoop hardness around ~ 2600; will do better with more wear-resistant steels and alloys with a more vanadium, at coarser-to-medium finish; not as effective on such steels at higher finish/polishing stages, because SiC still isn't quite as hard as vanadium carbide. Most wet-or-dry sandpaper utilizes SiC abrasive, but some wet/dry paper also uses aluminum oxide.
Diamond -> this is the hardest of all, being the hardest reference material on the Knoop scale, assigned a hardness value of 7000. Works THE BEST with uber-wear-resistant steels having a lot of vanadium content. Think of steels like S30V, S90V, S110V, etc. for sharpening on diamond.
Cubic boron nitride (CBN) -> Also works well with high-vanadium steels. Second place only to diamond in Knoop hardness, at around ~ 4500 or so. CBN is more expensive to produce than synthetic diamond though, so stones made from it can be pricey.
Chrome oxide ('chromium oxide', Cr2O3) -> this is the same stuff originally developed as a powdered pigment for green paint. It's what 'green compound' is ordinarily made of, though some 'green' compounds may be blended with aluminum oxide as well. It's less-hard than aluminum oxide (something like Knoop ~ 1700 or so). Ordinarily only used as a metal buffing/polishing compound; works well on simpler steels with not much wear-resistance (1095, CV, low-alloy stainless like 420HC, etc).
Great info guys, thanks a lot.
Fortytwo: how does one dress a ceramic rod? I have a sharpmaker and I want to avoid the problem you spoke of regarding the rods cutting power deminishing.
I wish I could understand everything being said here, but there are a few terms I'm not familiar with. I'm sure I'll pick these things up eventually.
Thanks guys,
Bo
Forty: Okay so just rub a diamond stone against it for a few strokes? Would 1000 grit work for this? Or if it's 3µ would 8000 grit be better? If I don't have a grit that high can I use 3000? I'm a little confused on what is considered fine or course in diamond stones when manufacturers don't assign a grit to them. I read that the higher grit edge pro stones have diamond in them. Will they work?
Good info everyone.
Thanks a lot guys,
Bo
They dont come with diamond belts but you can get them separately. I'm not sure if they offer them in sizes for the blade grinding attachment. You have to run it at a very low rpm and use oil or water so they don't wear out.Can someone tell me what the work sharp and Ken onion work sharp use in their abrasive belts? I read that they have special diamond ones specifically for ceramic knives, but I want to know what the original belts are.
Thanks,
Bk
Brian, are those belts for the grinder attachment or the KO as it comes? I havent even worn out any of the first KO belts that came with it.All of the stock WSKO belts are SiC or AlO3. The "coarse" is 120 grit as I recall. The others are X65, X22, X4, and the "6000" grit purple belt.
All of those "X" numbers are micron sizes. X65 is 65 micron. You can kinda sorta convert that to "grit" using the Grand Unified Grit Chart at the top of the forum.
I've been using some replacement belts from worksharp called the stiff Norax. Norax is a belt type from Norton that has some kind of helical striping of the abrasive on the belt. The stiff part is that the belts are stiff and don't flex as much as regular belts. I like them a lot and use the X200, X100, X22, and X5. I also ordered some extremely coarse belts from them: 80 grit (AlO3) and 60 grit ceramic. Both make short work of really super duper damaged blades.
Brian.
