Sebenza4ever
Banned
- Apr 15, 2005
WYK
You look very sharp yourself.
You're just trying to cause trouble ....WYK said:I can't say what the best slicer cutter is of the bunch - there's SO many knives out there. But I CAN say I heard it from someone who heard it from someone else that Cliff MIGHT have said it to someone else that it certianly wasn't a Sebenza!
WYK
kaosu04 said:WYK, I think I might have heard the same thing from the second someone else in your description. But that someone likes to gossip a lot. Someone (not the first someone from your post, just any someone) should have a chat with the second someone else.
Meat only needs a sharp blade because it can't exert any binding pressure on the sides of the knife as it falls open and isn't rigid. In comparison take something like a turnip and cut it with two knives and one can take ~10 lbs and the other ~30 lbs due to the geometry of the blade even when they are both equally sharp. Lots of materials need a lot more than just a sharp blade to allow them to be efficiently cut, thick ropes, cardboard, woods, etc. .guy g said:If I sharpen it, it will cut what I need cut. I cut stew meat with a machete once just to show myself it coulld be done.
I can clear up all the second hand info, it isn't the top cutting knife. An Opinel will significantly out cut it, so will many others, how much so depends on the media being cut.WYK said:But I CAN say I heard it from someone who heard it from someone else that Cliff MIGHT have said it to someone else that it certainly wasn't a Sebenza!
It depends on the extent of the grind and thickness of the blade, you can take a flat ground blade and hollow it out and it will cut better, such as you could hollow out an Opinel, just as lots of hollow ground blades can be flat ground and have the cutting performance improved like the Pacific Salt.Sebenza4ever said:Isnt Flat a better slicer cutter?
The Twistmaster has a stronger lock, significantly more so. More than once I forgot to unlock the Opinel and just popped the collar off by forcing the blade open, it doesn't take much effort. The security of both locks is however very high.digdeep said:1. Are they equivalent in strength?
2. Are they equivalent in easy or hard twisting to lock and unlock?
3. How do the steels of the blades compare, especially in ease of sharpening?
Have you have to tune the SAK edges, mine have been decent but I had to reshape all of them. They are easy enough to file though so it isn't difficult. Just curious if I lucked into overly thick ones.knifetester said:Opinel, followed by SAKs, followed by a properly sharpened Old Timer or Case Slip Joint.
Yes, I think that in general the design is probably user optimal. The edge is decently thin so it cuts well, but obtuse enough so that it handles really tough work. A lot of people use SAK blades really hard, scraping and cutting dirty materials. I fix them up for friends from time to time and usually cut down part of the edge but leave the rest more obtuse. My personal one is ground really thin, ~10 degrees or so per side.knifetester said:Most SAKs come scraping sharp with less than optimal edge geometery.
Yes that is my main carry.knifetester said:Is this the Rucksack reviewed on your site?
Yes, I pretty much always have it on me. I put a long length of cord through the laynard and ran a series of knots on it for grip when drawing from the pocket.Do you use it for EDC use?
It was the only one available locally with ergo handle, saw, and locking blade.Why did you select this model?
