Dave, I don't know if this will answer your question or not:
"Emery" is mostly aluminum oxide. Norton aluminum oxide is good. I use it all the time in 1" shop rolls and make my sanding blocks to fit. I buy it from the monthly sales catalogs from MSC Industrial. Enco may have it too.
When it comes to sheets, though, I use all silicon carbide, more popularly known as "Wet or Dry" paper. I use only 3M or Norton. they both cut well and hold up well to lubricated sanding. I buy it by the box of 50-100 sheets. Supergrit in PA usually has some good prices. i bought a paper cutter many years ago and use it to cut the paper into 1" strips or whatever as needed.
Another benefit of buying name brand paper is that the grit is well "classified", meaning the range of grit on the paper is very well controlled and narrow. No "stray" larger grit particles. Cheap paper isn't always so well made.
Hope that helps.
