Hi HoB!
It happens. Also, as more people start 'getting into' knives and finding places Bladeforums, it's natural for them to want to know "which steel is the best." I think what has happened in this case was more of a case of hearing "carbon is always better than stainless no matter what" and the original guy realizing "hey, no it's not. At least not this time." That was my take on the situation.
As for Dr. Landes' model, if you feel that sharpening more than 10 degrees per side is a mortal sin, it has merit. Yes, one of my pals took his ZDP-189 Spyderco brand Jess Horn folder down to 7 degrees per side, but it doesn't hold up to any of the work my Aogami Super Takeda Hamono brand chef knife does at a similar angle of C-Dawg's or gunmike1's chef knives with their 4.5 and 4 degree per side bevels. Mine has a microbevel that's closer to 12-13 per side, so maybe that's why mine's so durable?
I used to use it as a Deutschenkochemesser and that was a bad idea.
In sharpening a friend's mystery powdersteel (I think it's SKD-11 or SRS-15), I couldn't form a clean edge until added a robust microbevel (though I got a mirror-polished burr until then) and my pal w/the waifer-thin Jess Horn experienced the same when trying to put a 7.5 degree (15 included) edge on his friend's SKD-11 (powdered D2) chef knife. The "edge" literally broke off in places as he was transporting the knife to a local coffeehouse.
At thicker, but equally keen edges, I will readily admit that steels such as ZDP-189, VG-10, D2, and SG-2 blow 1095 hardened to RC58 out of the water (and rock the boat on harder 1095), but that's something covered by Landes' work as well. Hardness, carbide formation, and steel crystal composition (how much plate or lath martensite, how much upper or lower bainite....) generally determines which sort of steel will work better in a given application (I say "generally" because Brent Beach has D2 planes which outperform A2 planes and I have robust-edged knives in 13C26 that hold their edge better than similarly-ground knives in 154CM, S30V, and VG-10).
As far as Cliff's Crusades, I'd say their net results here were more negative than positive, but I don't dismiss the positives I was able to get from them.
Joshua J,
I think use makes a huge difference on top of that as well. When chopping vegetables with a French-style technique (forward/downward sheercuts with a rearward/upward return - looking like a piston on a choochoo train), I
destroy thinly-edged chef knives. When using a Japanese-style technique (pushing straight down with only a hint of forward or rearward movement to start and complete a cut), that same 10-12 degree per side edge lasts and lasts and lasts even though the food and cutting board are the same.
