Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
- Feb 13, 2007
I've seen that before and it wasn't bearings or tension, I think something is out of square. When the aluminum wheels are wearing funny it's because the belt is shifting as it goes around them.
In an ideal world the tracking wheel doesn't do anything. The more out of whack things get the more work it does.
Try running your grinder forward and reverse with and without the tracking wheel, should all be about the same. If it's not you might need to adjust something. I've had to turn the tracking wheel block some to get it running straight in a level neutral position. The drive wheel axle can be out of wacky, the platen or idler wheels can be wonky, or things can simply not be aligned so it requires an adjustment to get the belt centered. If that's the case don't track the belt over, move the platen.
This is my grinder
When you get everything straight, aligned and square it will track like that. That's the original tracking wheel, it's ten years old, it has thousands of hours on it and no real wear.
This is my grinder
