This should probably be moved over to Shop Talk.
Use MAPP over propane. Sure, you can overheat the blade with MAPP or Propane. Hold at 1475°F for 10 minutes and quench in the fastest oil you can find. Texaco 70 is around an 11 second oil I believe and is too slow for 1095. It will work with very thin 1095 cross sections, but only thin cross sections. I would use canola oil warmed to 130°F over that oil anyday. 1095 requires such a fast quench, brine is often used, so the Texaco 70 isn't the best option. Canola/peanut warmed to 130°F approaches the speed of a fast oil like P50.
Don't go buy color. Use the magnet. Here is the trick....magnet will stop sticking at around 1414°F. But you still need to be hotter.......like around 60°F or 70°F hotter. So simply notice what shade of red/orange you are at when the magnet stops sticking at 1414°F and then go "a shade or two hotter".....then try to hold that for 10 minutes.....then quench.
The magnet works very well...but so does judging heat by decalescence. You'll notice that as you are heating the blade towards the critical temperature around 1475°F that a "shadow" will move across the blade. This tells you, once the shadow is gone and starts to turn red/orange again that you have reached the steel's critical temp. Try to soak 10 minutes there. Decalescence being more accurate than the magnet.
