Thumb ramps are a mixed bag. The smaller and flatter, the better.
Rattly springs in assisted folders.
Recurves. Serrations. Don't worry about that CQC-7 of mine that you see from time to time.
Deep finger grooves in handles. For example, the Folts Minimalist: hard "no".
A handle like this
-View attachment 2727641
Smooth scales that get more narrow as you approach the blade and nothing to stop my finger from getting bloodied up unless I squeeze the handle like I’m trying to choke a rattlesnake to death. Also any knives with super slick shiny scales. I know they make them like that because they look pretty, but it’s like trying to hold on to a greased ice cube.
Finger choils. They take up blade length and I don’t like having my finger that close to the work. I just don’t like em !
Another thing I don’t like is slick, smooth handles. I have had a few really bad incidents with a knife that was as slippery as a wet bar of soap and nearly cut my femoral artery missing it by a mere 1/16 inch. I would rather have some texture for a good grip.
Samei don't like a handle to be thinner at the pommel than at the guard side
I don't like bearings at all, I won't buy a folder that has them. I stick with bronze washers mostly. I dislike flippers. I don't do much slick Ti. I have a small Sebenza I carry on occasion and that's about it.Flippers, finger choils and bearings.
Slick Ti handles.
I'm pretty picky about sheaths too, and we have similar opinions on them and choils. And I don't care for aggressive textured handles either. I live in the south, I seldom wear gloves.This is a good one, I hadn't had a knife like that before, and recently played with one of those Maxpedition MD inspired knives that has that type of taper, and it's very odd feeling.
Sheaths - I don't like busy kydex or leather. A stone pouch or sharpening steel loop is about it for me. I don't like kydex that comes too far up the handle also.
I'd rather a finger choil / ricasso be almost too small than overly large.
I've grown to dislike wide and deep jimping.
I dislike a lot of the jigging/stippling done on G-10. It's fine if the edges are broken and blended well, but a lot of makers leave it too rough.
I don't like frame locks either, or liner locks, or compression locks, or any other lock that depends on a detent ball to hold the blade closed in my pocket.FRAME LOCKS....
We're in 100% agreement on this. I hate a puukko handle that tapers from pommel to tip without even a speed bump between the handle and the edge.No finger protection from slipping up on blade is my #1 deal breaker.
I'm not the wolds biggest fan of finger choils myself, but if it is a knife designed for stabbing into things, I do like having an unsharpened area forward of the guard that doesn't cut my forefinger if T hook it around the guad to use the guad as a lever to twist the knife to losen it and anchor point for pulling the knife back out of whatever. One reason I love the Randall 11I’m not big on finger choils. They don’t help with anything, they just waste blade length. Just having a full sharpened blade all the way to the handle would be the same functionally but without a dumb half moon of blade missing from your knife.
In the 70s I made my own serrations the way DPX and ESEE serrations look using a chainsaw file. The blade was still sharpenable on a flat stone but still had the corners to tear with.Agreed with almost everything people have said. I only like serrations now because I learned to make good ones that don’t have the usual drawbacks that make many people dislike them, most particularly their difficulty to sharpen.
That and to have less pounds per inch applied to my forfinger in boring and tip work.@Mistwalker I get what you say about guards. It’s nice to have handle material that covers the ricasso area and also aids in preventing slipping up onto the blade.
Kitchen knives are a different matter. I'm seldom taking a kitchen knife to the field and boring holes in bamboo, leather, or wood. I'm used to the dropped edge of kitchen knives, and with no more force than I am going to apply to the tip I can keep my forefinger away from the dropped edge and not have to feel it pressing into my forefinger.However I believe a knife can be made that doesn’t have material on that part but still looks complete, is safe to use, and comfortable as well.
My EDChef model is an example. The integral guard, if that’s what we call it, is not covered by handle material (except on the limited number of EDChefs Mk II) but it’s chamfered, and at a sufficient angle and radius that there is little danger of cutting oneself outside of very careless use.
I don't much care for razel style blades either, or ones with really deep bellies either, I like a knife to have a preety sharp point on it.i dislike:
bearings in folders
finger choils, generally
linerlocks
slippery grip/handle
razel style blades
LOLI despise any knife that I don't own.
100% agreement on all of that. If I don't like the sheath, odds are I will not buy the knife. The carry system is as important, if not more important, a consideration for me as the knife is.Proprietary fasteners , style over function , unnecessary complexity .
Poor fitting sheaths with no way to adjust .
Sometimes I'm not crazy about tip up cary on any folders. Tip down seems to be safer with blades held in position with detent balls.Tip up carry only on large folders
Yeah, 13 years ago I bought a Cold Steel Trail Master from a friend here on the forum, and he had removed the top guard, I've recently bought a new trail master and a new recon scout, and I plan to remove the upper guard on both of them. I cannot stand a knife that doesn't have at least a speedbump between my forefinger and the edge. That's a deal breaker for me.No-No's For fixed blades:
> A guard which extends above the blade and interferes with my ability to extend my thumb onto the back of the blade.
> A handle which does not have a feature to prevent my hand from sliding forward onto the blade.
> Flat handles. Thin handles.
We're in agreement on all that. I hate metal handles in the winter. One of the things I hated ablout my older Gerber daggers.I don’t like metal/alloy handles because they are cold and slippery in winter/snow. Caveat- one of my favorite knives ever was a CRK Project 1 when not living up here.
I hate uncomfortable handles- especially squared, sharp angles on fixed blades mean’t to be used. I like deep handles that allow leverage maneuvering without having to grip tightly.
Crappy sheaths or no sheaths with a fixed blade purchase.
We think a lot alike. Except I do like some daggers. Daggers can be cool and useful in urban areas...they just suck at BushcraftNo daggers
No swords
No damascus
Only a couple of recurves
Only a couple of knives with < 4% Chrome
I avoid Aluminum scales
No partial tang fixed blades
No bad sheaths
US, European, Japanese or Taiwan made only from makers that I respect
Gotta be prepared for long lists when you ask a group of us humans to list things we don't like, especially lately when there is so much to dislike.Bunch of whiners in here!![]()
Tip up for me for all of my folders that clip to a front pocket. Things are only faster or slower depending on how you deploy and grip the knife and how you train. (Same with position of handguns). What works for one person is not necessarily best for another.Easier to take out and open quickly, too. With tip down, you're not stuffing the part you need to actuate down into the bottom of your pocket. (Yes, I know "waves" exist, to the 18 guys who wanna say it - but I'm over waves because they are not perfect, and are slower than Charlie Mike carry style of a fixed blade with over 6" blade, which if one carried for self defense, that would be a superior choice and method)
That's true, everyone has their opinions based on their experiences. Me, I've lost enough blood and clothes to tip up knives whose blades are held in place by detent balls on liners or frames. The only way I'll carry one of those will be tip down. That said, I carry my Bugout and my Delica tip up. I just sold an Emerson mini commander, a Buck Teranai, and a Para3 all for super low prices because they all have a design feature I don't care for. I own no more liner locks, and the only Frame lock I have left is a 90 something small Sebenza, and it only because...well it's an old Sebenza...Tip up for me for all of my folders that clip to a front pocket. Things are only faster or slower depending on how you deploy and grip the knife and how you train. (Same with position of handguns). What works for one person is not necessarily best for another.
I'm good with most clip points, I own several. But trailing points are iffy for me, being as fragile as they are.Clip and trailing points.
