With those two steel choices, O1 will be a much better fit if you have questionable means of heat treating. O1 benefits from a longer soak (say, 15-20 minutes at 1475) before quenching in oil. I've used canola in the past before switching to AAA (an engineered quenching oil for medium speed quenching). Heat the oil to around 130F prior to quench. This lowers viscosity and, when combined with agitating the knife tip to butt or spine to edge, prevent bubbles (a vapor jacket) from forming and insulating the steel. O1 is a deep hardening steel and will produce a servicable knife, though not ideal, from even basic heat treating. Bring the O1 up to non-magnetic, continue to heat it up for a bit, and watch the steel. When all the shadows dancing in the blade dissappear and the blade begins to glow more, you're in the neighborhood. If you can, try and keep the blade at that temperature for several minutes without overheating, then quench smoothly in oil. Once the blade is oil temperature, wipe it down and let it cool all the way to room temperature, then temper at 400-450 for 2 cycles of 2 hours each with a cool to room temperature between.
A2 is a poor choice for basic heat treating as it requires higher temperatures (around 1750-1800F) and needs a hold for 30+ minutes at temp. You really need a controlled and monitored forge or a heat treating oven for A2.
--nathan
