What do people like about the Dodo?
Back to the Dodo, do you guys think it is a highly specialized blade or does it have more uses than I am aware of.
When I had one, it did seem to cut a few things really well. The clamshell thing comes to mind. It has a pointy tip yet it is curved in like a claw. This design allows you to puncture something and then pivot the blade slowly so you can control the force of the cut. There is a built in lever in the blade. A highly upswept tip is the exact opposite. It is a slasher and you can lose control of it.
I guess everyone uses a knife differently and has different things they need to cut. That is why they make so many different blade shape. For me, a pointy 4" Warncliff blade is close to ideal for most tasks I need to accomplish.
I wouldn't call it highly specialized. It's not going to slice large, thick objects in half, obviously, but for work oriented cutting tasks and heavy duty cutting, it's pretty straightforward. It's just a hawkbill with a recurve, so if you use it like a hawkbill, which have many utility advantages, you will find that it performs exceedingly well.
I also love wharnecliffes for EDC, and have always thought a wharny blade in a Dodo would be awesome.
On the same note, I think a hawkbilled Lava would be an incredible little utility knife.
Have you taken a look at the yojimbo? It has a similar over sized handle (5in) with a smaller wharny blade (2.88in) I think i'm going to buy one of each and see which i prefer. I like larger folders, but i'm nore sure if its just for the larger handle or if its really the larger blade i like.
-Chris
I love the Dodo for the following reasons:
Debatebly the most ergonomic knife ever made (I would say the Manix has it slightly beat, but still)
I love the bb lock
I love wire clips
I love Spyderco G10
I like S30V
The blade shape is realllllly useful. It appears to be much more specialized than say the leaf shape blade--and that's because it is. But it's specialized for tasks that I think Joe Average encounters all the time. Opening mail, boxes, those stupid thick plastic packages that stuff you buy at Bestbuy come in, threads, twine, some rope--etc etc. These are the tasks I encounter all the time, and the Dodo is great at it.
Also, I'm not sure if anyone else knows, but there's an opening trick that, as best I can tell, can only be done with the Dodo that's pretty neat.
I find smaller blades like those on the Dodo (Spin, Cricket, Swick, Lava) to be safer than larger blades when cutting blister packs. Always felt like I was gonna hack off a finger when using something like an Endura. Paper and cardboard are like butter with that reverse S. Zipties and plastic bindings just pop upon contact with the blade. I also find it useful for cutting the sewn pockets on new suits and pants. ha
Well, that's teasing. Please describe!
I pretty much stayed out of this thread before now as I did not have any experience with the Dodo. As of a couple of days ago, that changed. Here is my take on the Dodo.
Well, what can I say about the Dodo that has not already been said. It is a knife that I have considered getting for a long time, but just never have. Almost all that own the Dodo, talk about how awesome it is. I finally decided that I should pick one up before they were all gone. The black plain edge models are not that easy to come by now and so when an offer came from one of the great guys on the Spyderco forum to get one, I jumped at the chance.
As has been said before, the Dodo is one knife that HAS TO BE HELD to appreciate it!! It just melts into your hand and locks there. Eric Glesser did an awesome job in ergonomics with this knife. It is a small but very mighty blade. This thing will cut open boxes and many other things with extreme ease! I am not sure I am really looking forward to sharpening time, but I think the corners of the Sharpmaker stones should work pretty well. S30V steel is my favorite which is another reason why I love this knife.
I like the Ball Bearing lock very much and this knife is a smooth opener. I have no problem working the BB lock with one hand.
I am very up in the air as to how much to use this knife. It is definitely made to be used and used hard, but I don't want anything to happen to it as it is a knife that is getting harder to replace. I don't think I will be able to get past using it some though, because it is just begging to cut something.
So, what else can I say. The Dodo is a great knife and it is well worth getting your hands one!! It has an intended use and it is a BEAST in that regard!!
I will leave you with some pics of my Dodo.
Ron
Agreed Ront, the Dodo was a knife ahead of it's time, it's the only knife i own multiple copies of, partly because of it's scarcity, partly to have backups
i have two blue SE models (one with CC# 130 that's my EDC), and one blue PE, i want to use my PE, but can't bring myself to do it because of it's rarity, if i was to break or damage that needle-sharp tip through normal use, it'd be a pain to reprofile
i do want to get another PE Dodo before they're all gone, as i would like to have a PE user Dodo, not just a safe-queen
my SE EDC Dodo has proved itself a capable knife, it's been used and used hard, i need to clean the ball lock once a week to clear impacted pocket lint, and i've already had to reprofile the tip to bring back the point (i broke the very tip of the point off somewhere), it lost it's needle-sharp tip, neccesitating a regrind, the tip is now slightly less pointy, but far stronger
it's eaten so many cardboard boxes and clampacks i've lost count, it's tolerated my ham-fisted (mmmmm........ham) first attempts at sharpening it on the Sharpmaker, withstood our salty coastal Maine air with only a slight patina of surface rust on the spine and inside the SpyderHole to show for it (Flitz takes it right off), and the G-10 has lost it's "toothy" grip, but it still grips well, this blade has taken everything i've thrown at it and come back begging for more
the Dodo *must* be re-released, in the same form, to change anything on it (blade shape, handle shape, open ball lock) would no longer make it a Dodo
it seems the reason the Dodo never sold well was;
1; it was "too expensive" for what many saw to be a "glorified boxcutter"
2; it was "ugly", people passed it by due to it's unconventional appearance, this is a knife that *needs* to be held, everyone i've handed the Dodo to to try out remarked on it's "ugly" appearance.......until they held it, as soon as they had it in hand, they understood, it was as if the metaphorical light bulb appeared over their heads and illuminated
3; the ball lock confuses NKP, it's not exactly intuitive for a NKP used to slipjoints or Buck style lockbacks to figure out that you need to pull the ball back to unlock the blade, however, once i explained the operation of the lock, the lightbulb lit up again
i will say this, once a NKP understands the operation of the ball lock, they are genuinely impressed, and many remark on how safe it appears to be
so, if the Dodo was to be resurrected, here's what i'd like to see;
release a "Classic" Dodo for Afis, change nothing, G-10, S30V, open ball lock, basically, bring the Dodo back into production, maybe add a Pikal style removable Emerson Wave
release a "Dodo Lightweight", basically, an FRN scaled Dodo, and depending on which is more financially feasable, use either the classic open ball lock, or the Pikal style shrouded ball lock, maybe make the Dodo Lightweight in the Seki factory with VG-10 if that'll bring the price-per-unit down
(or, if Stainless Steel handles are cheaper, a SS Dodo with the new etched handle treatment)
release a H-1 Steel version with a backlock
the Dodo is too good to let die, it *must* be reborn
the key here is to keep the price affordable, I passed on the Dodo at it's original pricing, only purchasing it once it went on clearance
+1 to any or all of these suggestions. I don't have a Dodo (but had a Cricket so I know what that blade shape can do) but it really seems like a knife that's meant to be used. I'd love to get one, but I don't want to pay crazy prices for a rare and discontinued shelf queen.
-Chris
I wouldn't advise the Yojimbo for anything other than very light utility use - the tip is very fine.
I was thinking about this knife since I saw it first time. Than last May I was able to handle it on Northeastern Show and I had a hard time to close this knife. The gentleman, who was selling Dodo, had hard time to close it as well. So I decided to forget about it.
Later guys on Spyderco forum convinced me to get Dodo. I was fortunate to buy blue PE in December. I ordered two of them, but I got only one. :( :( Dodo is my pain. I love its look, Dodo fits into my hand perfectly and it screams that it wants to cut and I cannot bring myself to do it, because I certainly will destroy it with my sharpening skills and I do not have backup piece. I live like this already a month. I have to get at least one more. I keep looking.
Sprint run would be perfect. Everything the same, just to change G10 color. I think it will be sold out as fast as sprint run ZDP-189 Delica4
hm, I can imagine people with larger hands having trouble closing the BB lock. I have small hands but if I let my nails grow, then I have difficulty getting a grip in the lock bevel. Otherwise, it's usually so smooth that I can flick it open and closed by pulling back on the lock.
richardallen, I LOVE that grind on the handle. awesome. looks like a flint tool combined with a modern blade and lock.
keno, did you do that handle yourself? It looks nice!
ashtxsniper, I have only one question for you. Have you held a Dodo? Don't just go by looks on this one!!
Ron
I love everything about the Dodo, from the theory behind it, to the execution in design, construction, and materials. But my hand doesn't fit the handle. :( I could never get a comfortable grip on the knife, so I sold it to a south-pawed knife nut friend of mine who really appreciates the ergonomics and the ambidexterity.
I like the handle, and the way it feels in the hand.
I like the blue handle scales.
I LOVE the Ball Bearing Lock for its simplicity, ingenuity and strength.
I HATE the S-curved blade.
-Jeffrey
