What do use to sharpen your Beckers?
Do you have a 'method' for getting the clamp in the same place to maintain the same angle each time you sharpen a knife? I JUST got one and haven't had to sharpen any single knife multiple times. Or do you find this to not be a problem?
Thanks.
I'm quite new to the Lansky, but I've played around with my EsKaBar for a couple of times.. the "problem" I first found is the wedge shape blade makes the clamp tilt from side to side... but I solved that by using the little notch for small blades on that BK14.
I havent found the problem you are describing.... Do you mean how "deep" in the clamp you put the blade??
All my knifes get sharpened on a Soft Arkansas, Hard Arkansas, then Loaded Strop.
If they're exceptionally dull I pull out the good old coarse/medium two sided silicon carbide stone.
