Don't suppose you have any pics of that sheath? Or, barring that, a more detailed description? I'm not familiar with this sort of sheath, but it sounds interesting.SleepingBear said:I like to carry my home-made quick release sheath with my Schrade LB8.
Gryffin said:Don't suppose you have any pics of that sheath? Or, barring that, a more detailed description? I'm not familiar with this sort of sheath, but it sounds interesting.
Haven't figured out how to add attachments to this reply, so I'll send you an e-mail w/attachments...I can handle that.
Breifly...it's a horizontal fitted sheath on your belt that as you draw out your knife, a rivet forces the blade open and locked fully drawn...and is a simple, quick one-handed draw. This works beautiful on the older lockback knives...and especially the ones that have the tight springs. I like also the fact the knife is worn horizontal on the belt...and can be worn for both right or left handed. You insert the knife into the sheath with the blade partially open...so as it's drawn out...the blade works against a rivet, pivoting the blade fully opened. If you don't need the quick draw mode...you just insert the knife into the sheath closed...and it is then drawn closed as well. This works on any folder..as long as you fit the sheath to the blade you want to use. The knife with the right sheath will never fall out. I personally carry all my folders this way, for the last 20 years and have made my own sheaths to each knife, and haven't used the conventional vertical set pouch sheaths since.This to me is...by far... the only way to carry a folder.
