Hey Greg.
You said, "Let me reiterate here....it all depends on the knife. Most knives do not have true fighting tips nor are they designed as fighting knives at all.
A true fighting knife tip (ala Bagwell Bowie type) will not withstand a direct drop onto or prying motion if it were the same hardness as the edge...no matter how good the HT or steel. You are better to have it bend where you can put it back rather than to risk losing it all together."
With all due respect, I must disagree. One respected smith has already added that his tips can still bend rather than break even at 62 Rc. I've spoken (well, conversed online) with other smiths who have similar views. However, rather than stand on their reputations, allow me to add some of my own experiences.
My big hunting Bowies do indeed have the same requirements of a large fighter, and the tips are fine enough for thrusting. Here's a few stories taken directly from my
coon hunting page to illustrate where I'm coming from.
"The coon started moving again, and I did NOT want him to get away, so I decided to try stabbing him through the three layers of chicken wire. To my surprise, the blade cut right through the wire, the coon, into the concrete bin foundation behind him. It actually took me a second to realize it. When the blade stopped abruptly, I just thought it didn't go through the wire, so I shoved harder and worked the handle, until I heard that grinding sound of the point in concrete. (I could barely see what I was doing cause of all the big weeds in my face and poor light) Though my thrust landed in a vital area, when I withdrew, the coon tried running again. Had my blade been too damaged to repeat the performance? Nope. Right through the wire again, and pinned him squealing in place 'till he succumbed in a few seconds. I know for a fact my fist big knife would have been too damaged to penetrate on that second thrust."
My first big knife that I mentioned above had a soft point. How did I know it would be too damaged to perform? One night after killing a coon in our grinder shed, I checked in the silo.... I got into a whole mess up there, but tried stabbing one coon, and the blade refused to penetrate! Seems the point got damaged and bent when I accidentally struck the concrete floor of the grinder shed earlier. I leaned my weight onto the handle, and it only shoved the coon down into the rotten silage- still refusing to penetrate. So I had to finish him with a draw cut.
That's certainly not the only times I've had a point take some serious abuse.
"So as I'm going thru the door, my hand is already on my Bowie, er, I mean Camp Knife, and the beam of my maglite meets the glowing eyes of this ugly assed possum in the cattle trough. As I got near, I drew the blade and made a big swing, but in my excitement, I didn't compensate for his movement at the last second, and I missed completely. Instead, I took a big slice out of the concrete floor, and mangled the last 3-4 milimeters of my point. I vividly recall the shower of sparks. Later, dad said he saw them too."
Same with folders, in this case my Benchmade Ares:
"Just after getting it, I shot a coon in our woodshed with a load of buckshot. Those damn vermin were crapping on a stack of seasoned walnut lumber we have been saving for making furniture, staining it and greatly reducing its beauty and value. He was still kicking, so I stuck him with the Ares. It went thru him and hit the concrete beneath him. As expected, it made a notch in the concrete, but only broke a tiny fraction of a millimeter off the tip of my blade, which I fixed in about thirty seconds with a diamond stone." Also once dropped a handmade folding fighter tip first onto a ceramic tile floor. It is double ground with a needle point, ATS-43 @ 62 Rc. Did half an inch shatter off the point? No, about 2 milimeters
bent to 90 degrees.
These are just a couple examples out of many. I am using a true fighting knife tip that you mentioned, and I'm doing a lot worse than simply dropping them on a floor. They are full hardness (same hardness as the rest of the blade), and they do hold up. For me, the choice does not seem to be as simple as, "hard will break, soft will bend". It's more like "hard will break off half a milimeter of the very tip, soft will dull/squash and bend 1/4 inch ". I still choose hard.
