What do you use to take photos of your traditional knives?
I got one of the newer Canon Powershot point and shoot cameras. The model# is ELPH 110 HS. Its really small and can easily be slipped into a pocket.
Compared to older inexpensive cameras I've owned from Nikon and Sony, this one really works well in natural light. I just switch the flash off and use the auto settings. It will also automatically switch to macro for taking close shots.
I'm no camera expert so this just works for me. I'm sure it does more than I'll even use.
This is what I need! I'm too tight fisted to spend much on a camera as I'm not at all interested in photography, plus I'm lazy & bored by the concept of having to fiddle about and stage everything. Your shot is more than good enough (Colt Bonestag I believe?)
Thanks, Will
Night time shot, taken indoors, with overhead fluorescent kitchen lighting....absolutely horrible and inexcusable quality from my iPhone 4S.
I would recommend taking the pics outdoors on a sunny day, but with the knife in the shade. That gives plenty of ambient light, which is essential for a good shot, but without glare and shadows. Smart people do this indoor with a light box - which is why I do it outside. I take my pics with a Samsung S2 Skyrocket phone, so you don't have to be fancy. Not the best pics on earth, but good enough for you poor saps to look at. :) And play with the exposure setting on your phone or camera. That can make a big difference.
Nice Shot!
But there is some serious PhotoShop or Gimp editing involved, is there not?
More crappy iPhone 4S pictures; maybe if I spend $1200.00 or more on a new digital Leica, I can improve the disgusting presentation my iPhone camera delivers...
You don't need a better camera. The iphones do well and the 4s did better than the 5 Imo. You need better lighting.
Kevin
I use either a cell phone or a point and shoot. I rarely use a DLSR for knives.
To post an example of showing detail with a lowly point and shoot I took the following. It is NOT a marvel of composition, nor is it dynamic and breathtaking lighting....
But, it shows even with a tiny sensor point and shoot you can share some detail with buddies on a forum.
L1000384-3 by Richstag, on Flickr
If you crop in to a less downsized and true to quality size it stops looking as nice...
L1000384-4 by Richstag, on Flickr
L1000384-5 by Richstag, on Flickr
Now you can see more of the limitations of the point and shoot. Lots of noise, not realistically sharp, lack of color detail, poor gradiants.
Overall, as a picture I rate myself on this one as a 5 out of 10. Very average in every way.
Especially since I did not even highlight the edges (the most important part of a knife).
But hey, even though its a boring, poorly staged picture with a point and shoot, my buds can see my knife on a cloudy day :)
I don't know much about camera phones - other than the fact that some people manage to take some very good shots with them.
As you've noted, lighting is the key. There are other considerations as well, but nail lighting and you've got most of the battle won.
Shooting outside helps, especially on cloudy overcast days (soft lighting that wraps the subject nicely). Bright sunlight (harsh) will "flatten" the subject and cause blown highlights (parts of the picture have no data). If it is a bright sunny day, try to shoot in filtered light or the shade.
Early morning or early evening light is usually the best for photography (around sunrise/sunset).
Do a web search for light boxes, photography lighting and the like. For a bit of money (often very little) you can make your own indoor lighting system. It can be nothing more than some heat lamps, bulbs, and plain shower curtains (to diffuse the light).
If you have a northern window - shoot by that (while indoors) to get some ambient light on the subject.
Direct lighting (on the subject) tends to be very harsh (as with the sun) and will flatten the subject out. Try to place the lighting so diffused light hits the subject from the sides or the back. Depending upon your desired picture, you may need to have additional lighting to help open up the shadows. (this can often be done with reflectors). For a backlit subject, you will need to light the subject from the front (otherwise the subject will be all black - or the background will blow out).
If you have white walls in your home, bounce the light off the walls (onto the subject). This diffuses the light and helps it wrap around the subject. Don't do this with colored walls, as that will usually impart a strange tint to your picture. You can substitute a large whiteboard (or something similar) if your walls are not white.
It helps to look at pictures you really like - study the lighting and the position of the camera - as that gives you an idea of how that particular picture was created.
Light temperature is important as well - too much of a difference and the final picture will have an odd color cast to it. That can sometimes be corrected with photo software (like gimp, etc..) but it is easier if you have the same temperatures for all lighting sources.
If your phone has the option of changing the white balance (color temperatures) use it when needed. One trick - if you like warmer photographs - is shooting with a slightly warmer white balance (like cloudy - on a sunny day).
Take shots from different angles. It'll help you figure out how the lighting affects the subject and what type of picture you like.
Photo software (many programs are free) is a big help - it can help remove noise, sharpen the subject, and correct the temperature. It won't work miracles though - the important thing is getting it right in the first place.
If you can select the ISO on your camera phone - always shoot with the lowest possible ISO. More light equals a lower ISO and a lower ISO means a slower shutter speed. A high ISO usually introduces grain.
I'm guessing that the aperture (on your phone) is fixed - but adjusting aperture will have an effect on the depth (amount that is in focus) and the shutter speed. Aperture is measured in fractions - f4, f5.6, etc... A smaller number is a larger opening (of the shutter) and lets in more light. A larger number is a smaller opening (of the shutter) and lets in less light. Generally speaking - the smaller number will result in less of the subject being in focus, and a larger number will result in more of the subject being in focus. Distance from the camera (to the subject) will have an impact on that amount of depth.
Put another way: if I shoot a subject that is 20 feet away at f4 the depth will be less than if I shot the subject (at f4) from 40 feet away.
Lower ISO will require slower shutter speeds; introducing camera shake (blurred pictures). If you have a tripod - use it. If not, either get one or sit the camera on a sturdy surface (when taking the shot).
It helps to use the timer - as pushing the shutter button can introduce camera shake.
Choose the background with care. You don't want the background to overpower the subject.
Frame the subject. Generally speaking, the subject should fill the frame (it should be the first thing people notice when looking at the picture).
Focus on the subject. It should be sharp and nicely defined.
Rule of thirds: imagine two vertical lines and two horizontal lines with each line dividing the frame by one third. One of the four intersections is usually considered to be the best place for the subject.
That said, don't be afraid to break the "rules." Some of the most interesting photographs do.
I've probably confused you more than I've helped, so I'll stop for now. Feel free to ask me any questions though; I'll try to check in on this thread so I can help answer them.
A few shots - notice where the light falls and the camera angle.
This was shot in natural light. I moved the stump to a better location so the light was diffused by trees. I also shot late in the day, so the lighting was directional.
This one was shot at night, in a tunnel. The only light source was a small lamp he used to read the music. I got down low and close because I wanted the viewer to feel as though they were there and I wanted the musician's emotion to show. This is the type of photography that I most enjoy doing.
Natural lighting coming over my left shoulder. I got down to the Butterfly's level, so the light would make the wing colors pop. I changed the background to black and white with photo editing software.
Natural lighting just a few seconds after sunset. The "rule of thirds" is shown in this one.
Natural lighting. Rule of thirds is shown in this one as well.
Natural lighting, taken at sunset.
Natural lighting, taken shortly after sunrise. I had to wait a bit longer than I wanted, because the truck was parked next to a big pile of round hay bales (and the sun had to clear the bales so it could highlight the truck).
Samsung Galaxy S2- I try to use the sun but get in a position where I'm not reflected in the photo-harder than it sounds.
My iPhone 4S; I never get that graininess that typically came with high speed/ISO films like Tri-X, or Fuji's 1600; and the odd thing is I use simple indoor overhead light, and don't get that yellowish tinge. No shutter speed, no aperture control, no filters, and I find the iPhone takes better pictures then my Leica Digilux.
My experience exactly. I've honestly never been able to take any better pics with a regular camera than I do with this iPhone 5. I get decent results by just using the i5, then upload them straight to Photobucket. Outside turns out better, taking it in the indirect light of shade on my front porch.
I pretty much use me old iPhone f4 for all my knife pics. It's ancient technology, and I have to wake the hamster up every now and then and coax him back onto the treadmill, but then I tend to take lots of pics, and then weed out the best ones, and then clean them up after they've been downloaded. You can accomplish a lot with decent software these days, assuming you start with a decent image. Most of mine are taken outside, with indirect light.
Tahts-a-dats-ago - your photos are seriously impressive. :thumbup:
I mostly use an entry-level DSLR indoors with a tripod and home-made light tent, shields, and reflectors.
Outdoors works well too, under the shade of a white plastic trash bag.
Or for un-artistic quick forum posts, a flatbed scanner.
Most of the photography issues I see here and elsewhere are due to one of the following reasons:
Incorrect white balance - If your photo is either too blue (cold) or too yellow (warm) then your white balance is not set correctly for the type of lighting you are using. Most cameras have a white balance setting. What you need to do is match that setting with the type of lighting you are using (i.e. fluorescent, halogen, sunlight, etc).
Grainy photo - This is typically due to low lighting. Your camera is having to use a high ISO setting to compensate for a lack of lighting in your shooting environment. The easiest solution is to put more light on the subject.
Too blurry - This can be caused by several issues:
1) For close-up shots it is best to use your camera's "Macro" setting (usually denoted by a flower). This allows the camera to focus better on close objects and adjusts settings for close conditions.
2) Hand-holding the camera is the most common reason for blurry images. In order to hand hold you need plenty of lighting so that the shutter speed will be fast enough to not catch "shake". The easiest way to solve this issue is to always use a tripod.
3) The last reason I'll mention is simply holding the camera so close to the subject that you never get focus lock. Using the macro setting above helps but be sure you're actually seeing your camera's auto-focus lock in before snapping the shutter. This is a very common problem on photos taken with an iPhone or iPad.
Excellent thread. This is exactly why I haven't posted more pictures. I've learned a lot right here.
Thank you - Bob
I have had good results with an iPhone using 645 pro app. This allows shooting in TIFF format, better for post production.
Here's a iPhone pic from a few inches away. Note the lovely swedge on that Stockman's main blade....
