- Aug 1, 2015
Sure. You said that right. But how is "sharp" really objective? When it comes to knives.
Aren't all opinions objective?
Exactly, sharp is an opinion.... or truth, aware of the fact or not..
Thin is certainly going to seem more "slicey". It's a matter of geometry, but with proper technique, even a thick behind the edge blade can slice, as long as it is sharp.I relate this term (slicey) to "thin", and not only behind the edge, but the whole blade. High hollow grinds can be very thin behind the edge, but bind up where the grind gets thick.
Slicey is high on my list when I'm shopping knives.
That sums it up for me. It's a subjective term obviously. Not rocket science. I sort of have a mental good-better-best categorization and the thin sharp blades tend to come out on top. But it is not something I dwell on.Slicey refers to a thinner ground blade that slices well. Most sharp knives will slice things like paper well enough; however it is when cutting through thicker materials that one finds out if a blade is slicey or not.
For example can the knife an apple in half without wedging the apple in half?
Yes. Think about a straight razor. Not slicey, but good at push cuts. Slicing is one way of cutting. Shaving and chopping are other ways a knife can be designed to cut as opposed to slicing.Can a knife be a good cutter without being slicey? How do we differentiate between good and bad cutters?
If a person says, “my Curtiss F3 isn’t slicey, but it’s a great cutter”, are they right, wrong, neither, or both?
Slightly toothy edges seem to slice better in general.Yes. Think about a straight razor. Not slicey, but good at push cuts. Slicing is one way of cutting. Shaving and chopping are other ways a knife can be designed to cut as opposed to slicing.
Yes, thin definitely does seem slicier.Thin is certainly going to seem more "slicey". It's a matter of geometry, but with proper technique, even a thick behind the edge blade can slice, as long as it is sharp.
On my "super slicers," you can gently press the side of the blade across a fingernail and see the edge flex.
This must be some darn slicey knives ! This is razor territory : the thumbnail test is how Böker controls the edge of their straight razors (to see if the desired thinness is obtained). Cuts like lightning but such a thin edge is very sensitive. For soft materials exclusively.
