Say Heah Boys and Girls, My Bokor is the 110273BB a Jig Bone 2 Blade High Carbon Stainless, around a $45.00 price tag with the Leather Pouch in a nice box, Any info, Please Chime in.
Sent from my SM-N900T using Tapatalk
Perhaps its NOS? the knife I have inbound is stamped, H Boker 7 Co Solingen. Did I get caught up in the hype of "high carbon" its not similar to GEC 1095 carbon right?
By definition, "high carbon steel" simply means it's got at least 0.4%-0.5% carbon or more; this compares to steels like 420HC and other simple cutlery from Victorinox, Boker, Wusthof, etc. Basically, it's just enough to make decently hardenable cutlery, i.e., knives that can be heat-treated to take and hold a sharp cutting edge within minimally realistic expectations. Other than simple kitchen flatware like true 'butter knives' (which are low- or very low carbon), most knives with sharpened edges will meet that standard anyway; some just barely.
Technically, it should be 0.5% or higher to be called 'high carbon' steel, according to strictest steel industry definition. But more widely, some makers will 'fudge' the labelling a bit, like so-called '420HC' ('HC' implying high carbon, having more than regular '420' steel), though it has slightly less carbon than meets the definition, at around 0.45%. Other makers can still make reasonably sharpenable knives with carbon content down around 0.35%, which would be at the low end of the 'medium-carbon steel' definition.
David
It seems pretty goofy for boker to make knives in china and assemble in germany to keep the cost down, I though thats what plus and magnum are for but whatever floats their boat. I suppose these china/german knives are decent value though.
You should start a new thread for this, and give it a title that indicates that you need help finding a new knife. I’m sure you will get some good suggestions.My first post... I am shopping for a pocket user, the first in ... gads! ... I can't remember how long. May have been a Buck ... 301-similar ... when my 41 year old son was 5, maybe. It was lost not too long afterwards. There have been fits and starts since, but nothing as purpose specific as an "easy to carry" in my jeans. I found this thread while searching for typical blade steels made in the current USA, or well made Western manufacture offerings.
My latest acquisitions, the "fit/start" pieces, was a slippery slip-lock Queen Oar Carver in pretty horrid shape for using; and then, its sibling a locking Oar that was in horrible as-made, condition. I keep the second knife open because a pair of pliers is required to open the blade. Both of these knives also have pm-D2 blades that are nearly impossible to sharpen and fold over edges upon touching wood. I'll pass on Queen. Oh, wait! They are out of business.
So far I have found three decent traditional pocket knife manufacturers. Case and Buck in the USA and; Boker out of Solingen, Germany. All of these names offer Chinese knockoffs. I have no interest in the Asian sourced item, or parts assembled elsewhere. Someone might throw in Great Eastern Cutlery, but (GEC) doesn't make users and I don't care about collector criteria, which GEC must cater to. I'm not sure GEC is still around now, in April 2022.
Choosing the Knife Companion--
As noted in the lead-in, I am seeking a non-stainless traditional pocket knife steel. That is not an easy accomplishment. Case has some. Boker (Solingen) has one (out of stock) that fits the criteria I have. Buck has none. My early 110 is a solid member of Buck, but not a pocket carry, nor non-stainless. Even Buck defers to its 420-HC "approaching" carbon steel (non-stainless) in edge and hardness capabilities. As noted in previous posts, the home manufactories steels for these brands have not changed.
To fit in my pocket requires a knife easy to lose. That means length is 3" to 3.5", with two blades and maybe a third. Substance is important. Boker generally uses thicker steel and liners than the American products. But I have really narrowed my criteria so I can only critique the samples I have to choose from, then return all but one, maybe two.
I currently have six knives and expect two more, only one of which fits the criteria so far. Sort of. They are two Boker Barlows; one is a single blade, I think C75. The other is the traditional 2-blade but in Stainless.
The knife needs to fit my hand. One is a Case Peanut, under three inches. It's too small. The criteria were modified to require full palm use. Three fingers was not enough.
Then, they can grow to be too big. But big includes blade quantity too. I have a vintage one-blade Tina 640/10 worn out from pruning/grafting--roses, I think--and the blade configuration is not amenable to typical whittling. The length at 3-7/8" is too long. I really wanted it to fill the pocket carry role. As a vintage store capture, Tina is the cheapest knife I have. New, it would be the costliest.
All the knives over 3.5" are long. So, the one Boker Congress 4-blade whittler, in non-stainless steel, is too long and too big. However, I really want it even though it will be modified. Probably my costliest knife to date, and it would join the current record holders that were also modified. Someone mentioned Hen and Rooster. I also have that in Congress whittler copy, but it is a really sad tool in fit, finish, and general construction quality.
Safety is a bigger concern than I originally expected. The ideal blade for me is the Case Pen, or the Buck 301. I wrote off the Buck in the first moments of my search. Mine was a nice tool, what I remember, but I think the black scales made it easy to lose and miss in a hectic moment. The Case 32087 CV, however, is a weak slip joint. I have tried 4 and will have an additional two to test later tonite. I know Case can make a knife with half and full snap stops. Two peanuts I looked at, one I have, work beautifully. The final safety feature is what I call Rambo Syndrome. Most people will not be intimidated when I pull out a three-inch pocket knife. I am not interested in looking for or expecting a rabid deer, or rabid Rambo to protect myself by wearing a bear sticker. I know I can do pretty well with two inches. The "Pen" just requires a careful hand. It is dainty.
Conclusion.
In retrospect, my preference for non-stainless has been seriously battered on another forum. For any reasonable choice to be made, it should not be based on type of steel. They all are about the same in the modest pocket folding category. The choice really needs to reflect the user's comfort in carry, use, and social benefit.
Damn I bought an outsourced oneIf that is the knife the " Germany " on the shield means it was outsourced with parts from China and assembled in Germany, should have been sold at a lower price point, but there are some shady auction site sellers and venders that pass them off as the Solingen made ones, next time try to read the shield if it read SOLINGEN you have a 100% made in Germany knife.
Pete
