- Apr 12, 2009
OK. Looks like you're in the ballpark. But, in reference to what I was saying earlier, this is where I think you'll benefit by looking at the edge under magnification. I use the Sharpie, also. Oftentimes, by the naked eye, it appears that the black marker has been removed all the way to the edge. But, I've often discovered, when looking through the magnifier, that there's still a VERY thin black stripe along the edge, indicating you're very close, but not quite there. And as I said earlier, the magnified view will also show you what else might be going on (like rounding, or if the edge isn't fully apexed in some areas). Conversely, if you have fully apexed the edge, from both sides, that should also become very clear. A good, sharp edge is inherently very attractive to look at, up close. Very clean, sharp and pure, to a nice 'V' shape (even if gently convexed).
I believe I can see, in the pic you posted, what appears to be a remnant of the original bevel near the tip. In my experience, that's common. The edge is usually the thickest there, and takes more work to smooth it out.
