- Apr 13, 2004
I reckon 3v will be king of the mountain.
I'm not so sure.
I'm not so sure.
I am pretty sure SR101 has 5% chrome. SR101, isn't exactly 52100, it is modified 52100
I don't think it make sense to call 1% Carbon with 5% Chrome steel as a modified 52100... do you know that 52100 is oil hardening steel and by adding additional 3.5% would high likely make it an air hardening steel... completely different animal in my book...
by this logic I can call A2 as a modified W2 too... that was pretty dump isn't it?
52100 is a ball bearing steel made via vacuum melt process.
Since ball bearing application demands high quality material, therefore every ball bearing steel such as Bohler's R100, Carpenter's 52100 and most of any company product will have very tight spec which have very alike composition... 1% Carbon, 1.5%Chromium with a hint of silicon and manganese...
Do you have any source to back up your word that SR101 has 5% chrome?
man, from my exprience of using rats & dogs , i felt that sr101 does not have such high amount of Chromium , cauz that sr101 is more easy to rust than 1095 .It doesn't matter what you think. If it is called that, then that is what it is called, regardless of what YOU think. Fact is, this is done all the time. A8 and Modified A8 with 3% more chrome for example.
As for my word, my word was gotten from a very well known knife maker in the industry(and I have no reason to tell you who it is). Is it true? I do not know. I have not verified it myself, but it certainly goes well with the description of SR101 by Busse. but since you are on this forum and asking you must own some SR101, so why don't you go test it and see?
if the Sr101 has 5% Chromium & 1% carbon , there must be some resistance to rust.![]()
I completely agree that 5% chrome would make it an air hardening steel which means that it could not be deferentially heat treated like the old Rats were also at that chrome level it would have comparable rust resistance to A2 which SR101 simply doesn't have it will rust much quicker than A2.
That being said I am still very happy with all my SR101 knives and have never had a doubt that they would perform what tasks I have asked from them.
Chromium content doesn't automaticallyctranslate to corrosion resistance, especially at such low levels. Sometimes it's used to impart other qualities to the finished blade.
This is exactly right, and what most people don't understand about properties of steel. It is funny how you can increase toughness by adding Cr to a point and then toughness begins to drop with more Cr. Most chipper steels, which are very tough, have between 5 and 8% Cr. After that toughness drops off fast with more Cr.
for real , man?
