- Jun 7, 2002
i use sandpaper which uses carborundum (600 to say 2000). the cheaper ones, i suspect, contain only silica because i tried to polish an s30v military and it hardly wore out the original grind when done purely by hand. i had to tape the paper on a wooden block, and run the blade across it with pressure, a bit like those japanese sword polishers.
as jason explained in a previous thread, a high-vanadium blade is a like a concreted road. when new, the surface is pure concrete. in time, the concrete disintegrates and the rock aggregates are exposed. using a medium that's softer than the rock (say tires in conjunction with sand from the worn cement), you will keep eating at the cement and the rocks will jut out more.
