What I Would Like To See Buck Make
Please, make also blade thicker then on regular 110. It will be more tactickal then anithing else around!
I thick it should be twice thicker plus TiAlN. Also pivot scrue will be a good idea.
I'll try to draw it...
Blade geometry is perfect you mau just try to run 880 with this blade to see how great it will be.
Thanks, Vassili.
If they can make one, make 3. I'll take 2. :D I still think it could be a real strong seller.
Thought I had seen some mention of neo 110s. Awesome idea, if titanium bolsters were doable then it would make a great custom shop model. G10 is a good start but I think Ironwood, cocaboaa and micarta would work well too. S30v or BG42, if ya wanted to get fancy you could anodize the bolsters. And at the risk of offending the traditionalists an optional clip would be nice. Yeah I know and I did say optional, but based on the knives people seem to be dropping hundreds of dollars a pop on people (myself included) like clips and find them useful. I don't think attaching a well designed titanium clip onto the 110 would do any damage to its excellent lines. Of course the other option would be to leave the 110 without a clip but offering a mini model (112) that did have a pocket clip. Maybe even an opening disc or a blade cut out. Again I think these to methods would do the least damage to the knifes lines. Last thing (I promise) how about some serrations on the bolsters, back and front.
my 2 cents and again, great idea ya'll
Sam
Folding Alpha Hunter (277 model), aluminum or titanium frame, G10 handle, S30V or BG-42 blade. Perfect blade shape already, but lose the small choil on the blade for more cutting edge.
The perfect utility - tactical hybrid. And an ideal EDC.
I have 4 Alpha Hunter's already. They're just too heavy for an EDC.
hummm... hay joe,, on the clip do they not rember the 180? and i have seen clips on the brass and nickal 110 also as for macarita in a brass 110 - i have seen brown macarta in a 110 handle in some ones colection and it is not that impresseve. the bg 10 in brass would be very doable by the custom shop no problumblemoo..and imagen the gripability of such a 110! humm do it on the new ver of the 110 that has the difrent angles on the scales. as for the standerd 110 in thi... yes a lot of work but could be done by your custom shop on a bet ... but only if the supervisers stayed out/away of it for a while :)
