It has visible grooves, but they are BARELY visible. This steel was my great grandfathers. To the touch and casual glance it is smooth. But I will try that. The stick across the blade didn't work. Btw, one knife is a spyderco with VG-1, one is a case saddlehorn Bose style?, and two are AG Russell with 8cr13mov.
Are you sure the Spyderco isn't actually VG-10? And is the 'Bose style' Case saddlehorn one of the collaboration knives ($$$) or one of Case's standard line in 'Tru-Sharp' stainless or CV? If a standard line knife from Case, the pattern number stamped on one of the blades will clarify. The pricey Bose collaboration line from Case is a whole other animal; normally in 154CM steel, if I recall.
Reason I ask is, both VG-10 from Spyderco and 420HC ('Tru-Sharp' stainless) from Case are prone to burrs anyway. Pressure is what creates them and makes them bigger. Rod-type hones focus pressure in a small contact area against the edge, therefore contributing to burr formation.
As mentioned, grooved steels aren't good for eliminating burrs, and will usually create some big ones instead.
A simple bench stone in silicon carbide or aluminum oxide (think of Norton's Crystolon or India, respectively), or wet/dry sandpaper can work great for Case's blades, from beginning to end. VG-10 could be re-bevelled on diamond or silicon carbide hones quite easily, then finished and/or polished with finer grits of the same or on aluminum oxide, or also on wet/dry paper over a firm backing (wood, glass) with edge-trailing strokes. Trailing-edge sharpening on sandpaper is more tolerant of pressure (within reason; still keep it light), and will reduce the size of burrs left.
BTW, the 8Cr13MoV responds nicely to SiC/AlOx/wet-dry sandpaper honing as well, much like the Case blades. Burrs shouldn't be quite as bad, if heat treat is decent (I'd expect this from A.G. Russell; I have several of his in the same steel).
David
