- Jul 30, 2006
I test them at work in the metallurgical lab. I'll have to go look up the hardness tester brand. It is kept in calibration (Calibration is required by Nadcap and others. We are Nadcap certified). I am aware of the ±1 tolerance for hardness measurement. I intended my statement of the 301 hardness only to show that Buck claims a nominal hardness of 58 and the knife I measured meets their spec.
I'm sorry, which alloy are you talking about?
(Since Spyderco uses neither 425M nor 420HC, I am not certain I would expect them to be an authority on the composition of either. Neither 425M nor 420HC is a standard alloy, so either can vary in composition depending on who makes it. If we really want to know what Buck used, perhaps one of the Buck folks would care to pull up an old data sheet out of their files (assuming they have not been 5S'ed.)
No matter what the composition, I think you already stated the performance which was the real question that the OP wanted to get at. And I think your assessment, (that it is good stuff) is a reasonable assessment of the performance. The only reason that I entered into the conversation at all was because no one had stated a composition. If you do not agree with the composition stated by my sources, I cannot help that. They are published sources. One of them a steel producer, the other a well known steel metallurgist.
I'm outa here.
I'm outa here.
