Hi Guys,
I am posting this question here because I see you as the main users of scandi grinds
I need your combined advice
The story:
I have received a 4" custom Woodlore clone in 01
My first custom
Lovely knife
No names.....and the maker will remain private
The grind from the website is a scandi with a secondary micro convex bevel
What is reasonable to expect this to be.
I am going to defer to your greater knowledge in making up my mind what to do
I wrote
"The secondary micro convex bevel is actually a full blown secondary bevel.
The cutting edge is now the secondary bevel and the Scandi is rendered as cosmetic, where the edge could be a saber grind.
The secondary grind has cut into the Scandi edge deep enough to have the cutting edge be a much more obtuse angle
So to cut I need to pick the blade up and use the secondary edge and the Scandi geometry of the blade is not used"
The secondary edge is a measureble 1/32"
Without grinding back to close to the scandi grind, I will never have a scandi grind, at each sharpening I will always be deepening the secondary bevel
Your advice please
thank you
The story:
My first custom
Lovely knife
Your advice please
thank you
