For a minute, I was going to write "Cognitive Behavioral Therapy" but then I realized this is BF. None of the Busse addicts need that...right?
Except for the HG55, they run the wrong direction. I still want one!They actually reduce weight while adding lateral strength.
Hate to nitpick, but this is actually incorrect.
If you have reduced weight by adding fullers, the structure is not as strong as it was. The corrugations are like a bunch of small fullers.
It is like the concept of structural I-Beams. The I-beam is lighter than a solid beam of the same external dimensions, and nearly as strong. It is stronger than an equivalent beam of the same mass, but much larger in dimension.
So your saying it reduces weight but doesn't not add any extra strength?
Corrugated Bevel Technology. CGFBM, Hellrazor, Jackhammer, HG55 all have it. The original versions, at least.
Do the bevels hinder chopping or cutting tasks?
I believe they are supposed to aid in chopping as it reduces sticking into the wood your chopping
What is CBT?
Still learning the lingo. I have seen a few posts in the Exchange that refer to a CBT. What is that, exactly?
Thank you.
