kreole
- Jul 23, 2009
The issue isn't as much around the use of the letters "CPM" as it is the use of the letters "CM". If the designation for a 154-based steel has a "CM" following it, I assume it's 154CM regardless of whether the letters "CPM" precede it or not. If the designation for a 154-based steel starts with "CPM" but does NOT have the letters "CM" following it, I assume it's CPM-154. Or to put it more simply:
154CM = 154CM
CPM154CM = 154CM
CPM154 = CPM154
Having said that, I don't like to make assumptions, especially when there's so much confusion about the different designations. If you're in doubt, I'd suggest you contact the manufacturer of the knife and ask them which alloy their using.
Are you sure about the second equation?
