What is needed to start making knives?
Yeah thanks for your videos Aaron. I borrowed your beveling jig idea and made something very similar that I can clamp on the bench.
I would suggest that all of us newbies check out your time lapse video on making knives with common tools. I watched that about 10 times and always find inspiration.
As a fellow Canuck I noticed the Mastercraft bench vise right away. Cheers mate!
Dan
Hey, I've got nothing against using an angle grinder! Use what you've got on hand! I'm no snob!
Its not that its all I have on hand i just prefer the more "hands-on" approach I have a belt sander and a bench grinder but the good Ole' angle grinder is the only one that I like to use for shaping
Dan
Glad to hear that the video was helpful mate! Best of luck!
Aaron,
Thanks for posting those videos. I wish I had seen your jig set up before I built mine. I'm going to have to use some of your design to rebuild mine, like the stop bolt. I used a clamp as a guide but a bolt would be more stable.
Your videos are a great example of how a really nice knife can be made with inexpensive tools.
I'm ready to heat treat my second knife and about to build a small can forge to heat the blade. My first blade was tiny so I was able to heat it using a propane burner and torch, but my second knife is larger and needs more even heat. I can't find soft fire brick locally, so I'm going to try using plaster and sand in a soup/coffee can forge. This will cost me only $5 for the plaster of paris. I already have a small torch and the sand and can will be free. If it works, great, but if not I won't be out much money on the experiment.
Aaron,
I've seen a few people successfully use the paint can style forge. The only advice I can give is: don't make it too big. The bigger the chamber is the more heat you'll need to pump in to get your knives hot enough. If you're using just a propane torch then you need to keep that chamber small indeed!
Best of luck mate! It really is a very rewarding hobby!
