A bit more edge length in a given total length. The "bite" in the cutting action is that the curved blade drops a bit behind the material being cut often giving more cutting surface to work with a cutting stroke. It can improve the cutting action in some cases.
But I think the recurve is over-rated and has more minuses than positives.
Phil
Besides the learning curve for sharpening what disadvatages?
scares away potential buyers who aren't ready for radical blade shapes![]()
are we talking kershaw blade shapes, or spyderco civilian or cricket here ?
Recurves add a lot of cutting area , and offer the hooking ability of a hawkbill without sacrificing the point, and isolates areas of the edge so one area can stay sharp while you abuse the other
if its the spyderco cricket shape, its a hawkbill with added edge length
if its a large chopper, it puts more weight forward
Note that the harpy doesn't have a profile we would normally call recurve. It has a hawkbill blade. The khukuri is an example of a recurve blade. It has a convex area near the front of the blade.
Both are slashing blades. Tactical. Neither offer any advantages for general cutting applications.
Take the food prep angle for example. With a recurve, when you bring the edge down, it doesn't cut through the material all the way. You have to draw the knife back in the cut to complete the cut. This is true in any cut made against a flat surface where a recurve increases the work to make the cut.
I find recurves more difficult to use in fine control cuts. The kinesthetic sense of where the rest of blade is is often thrown off by the recurve.
Besides learning to sharpen a recurve, they require special equipment to sharpen compared to standard blade shapes. With the sharpmaker for instance, you can't polish a recurve edge as other edges simply because the recurve can't be sharpened on the flats.
The increased cutting efficiency is smaller than claimed in my experience too. Simply angling the blade in the cut can achieve many of the gains claimed for a recurve.
