I know there is not a blanket answer for this question, but here is what I have learned, maybe that will help you know what i'm looking for.
I am looking to make a few knives out of the hardest metal I can find. I have seen a few blades out of M2, but no manufacturers. Looking at some data about M steels, it seems M4 is the highest end as far as hardness (63 in the case of M4) without sacrificing toughness and becoming brittle. Sure higher M steels such as M42 can get much much harder, but it seems anything above M4 just gets brittle. M4 seems to be able to go to 63 rhc before getting brittle
I know that D2 is the most popular steel for higher end knives. Its very hard and is basically stainless. But what about the higher end D steels. I know some people use D6.
And then there is CPM Rex 121. So far in my research it seems this is the "ultimate". In fact if you google CPM Rex 121 you see almost nothing but knives. And the Crucible data shows it can get to 70.5 hardness without sacrificing toughness. Thats crazy hard. But i'm told it cannot be bought in flatstock, which means I have to either pay someone to forge it, or buy a furnace and anvil (i did see a guy get metal red hot with a torch and a few firebricks).
What would you conciser to be the "ultimate" steel for building a super hard super slicing knife?
Side question, what grind should i use with these super hard metals. will a plain V grind be sufficient or is it necessary to do a convex edge?
Thanks for the info and advice.
