Originally posted by rockrewls
I use my knife 99% of the time for skining and deboning ...cut a willow branch ... no real prying or hammering or chopping. ... want to be able to put a extremly aggressive edge on it and have it hold for a very long time, keep in mind this blade will occasionally hit bone, so it must endure some punishment. I am looking for the absolute best steel type. I am considering BG-42...Dale
Do you value the property of being at least somewhat stainless?
For stainless steels:
At this juncture in time, S30V might be a small upgrade from BG-42. S90V will hold an edge better than either strictly speaking, but S90V is less tough than S30V for sure and probably about the same toughness or a bit less than BG-42. It doesn't sound like S90V would be a problem if you use the knife as indicated. (know that you really must have diamond stones to sharpen S90V with any efficiency at all).
D2 is quite a good edge holder, and is almost stainless, not quite, depending on the source and heat treat. A good D2 blade can be had, generally, at a cheaper price than for the CPM's, and is in the same general range as BG-42 in toughness (i.e. ok but not a tough steel).
For a non-stainless steels:
CPM 3V will hold an edge about like D2 (some say better) but will be extremely tough if treated to between Rc58 and Rc60.
CPM 10V will outlast all of the above in edge holding if run hard (at least Rc60), but again will sacrifice toughness to do so vs. say 3V.
Aggressiveness of edge:
depending on what you mean by this, you can accomplish this through the grit of stone you use. Example, I often leave a "coarse" diamond edge on my knives if I want a grabby edge, coarse in this case from DMT isn't exactly that coarse.
For the applications you mention (skinning, boning, might hit bone, but won't be used for chopping or prying), harder is better when it comes to heat treat, assuming you contract with a competent maker/heat treater. For many steels, and in very general terms again, Rc61 is about max before some brittleness creeps in. You could run 10V at maybe Rc62 and not have trouble with chipping if you use as you've indicated.
Next question: who are you looking at for a custom maker? If you want to push the CPM's to the limit and want a really nice hunting knife, I'd have a phone conversation with Phil Wilson. Here is an email address for Phil... unsure if it's still current:
seamount@bigplanet.com
Or see this thread:
http://www.bladeforums.com/forums/showthread.php?s=&threadid=91928&highlight=phil+wilson+address
