- Jan 5, 2008
I am in need of a good stone for sharpening. I know there are different grades and I would like one that could do it all. Any advice would be greatly appreciated.
Thanks
Thanks
skip the stones, try this method
http://barkriverknives.com/home.html
I could never sharpen before, this way I can shave
Interesting approach. What type of paper is used?
Even more important than type of sharpener is your technique- practice until you get the results you are looking for.
That method works very well. Not only for convexed knives, but you can convex a secondary edge bevel, sometimes refereed to as the "Moran Edge". Works very well and creates a edge that will last for a long time in good steel.
You can build one out of a mouse pad and a small block of wood. I glued a mouse pad to a 1X2, cut some slits on the end of the 1X2 so you could stuff the extra paper into the slots, and shim it up with tooth picks. Works great.
Edited to add:
If it's stones you're after, and don't mind spending some $$$. The King brand wet stones are fantastic. I really didn't know what a polished edge was until I used wet stones.
They will run you a fair amount of money though. I have a 250-800-1000-4000 grit stones. The Japanese grit system is different than our system.
The 250 is for major re-profiling, and I mean major. The 800 is to bring an edge back....ect.....
The 4000 can truly polish and edge. For wood working, I like a polished edge, otherwise I just finish it off with the 1000, and a loaded strop.
Could you post a picture of the wood block setup being made? Thanks
