- Jun 4, 2010
ToddS, will diamond not create a foil burr no matter what is used to strop for the BESS test? Since I think we are looking for the keenest edge at the lowest angle then diamond would be a good abrasive as it cuts with so low a force, so that fine apex deforms the least while cutting it. I have diamond down to .1 micron with each size up double the last. I only have a light microscope so probably won't be able to see the foil burr if it's less than .0005" or so in size. What do you suggest to remove that tiny foil burr, assuming there will be one?
I am thinking the target BESS test in mind will be with a top secret new SS for knives, just a guess.
HH, trying paper is easy since I am using EP polish tape blanks, and have a few seconds I can modify if need be. I can fold the paper over and take it to the back where the two edges come together to present a very even surface to the knife. I like the idea of keeping the softer bond to a minimum thickness. I expect it will be firmer than the leather. Are there specific papers for that ultimate polish? Vellum? What does compressing do? I have a vise with precision flat surfaces that I can get up to 12,000 lbs of clamp pressure to do this with. I do it when gluing the leather to the aluminum carriers, it really helps flatten them out!
Compressing the paper just makes it more dense, this is a better strategy for working knives where you want the deepest scratch per abrasive. This also the reason for using a coarse stone or other open surface, it increases the unit pressure. When sharpening woodworking tools I finish with one or even two sheets of paper with chromium oxide. For a utility edge I use one thin sheet with more applied pressure.
