I guess everyone isn't as cheap as I am.
I use the tip of my knife to release the ziptie latch so I can reuse them as necessary.
So I was posting a reply to another thread and thought about the way I cut zip ties scares me more and more as I get older. Is there a proper way to do it? Sometimes I can sandwich the zip tie between the blade and my wooden workbench. My blades are sharp so pressing down makes the cut pretty quickly. However, most times the zip tie is too tight and I can't use that method. I end up pushing the blade away from me into the air with quite a bit of force and then when the cut is made the knife jumps forward. Of course I make sure I am clear of any other humans, animals or anything else that I don't want to harm or damage but still feel a little barbaric.
Am I doing it wrong?
Thanks
I have a boxful of different sizes when I need one.
It is a piece of cake. Open your Leatherman and use the wire cutting section of your pliers. Fast and easy.
Frailer, that is some good stitching by the way. What kind of knife will you use to remove those stitches?
