What is the difference between a clip and a drop point?
OilMan
I've often wondered what the difference is between the two. To my thinking a drop point goes straight from the top (spine) of the blade to the point and a clip is the same thing except it has a downward curve to it. Am I close? :confused: Some points almost look like they could be both.:confused:
mee dum,
oil
It's the blade shape, but you knew that. The Buck 119 Special is a good example of a clip point, while a Loveless drop point hunter is a perfect Drop Point example.
Yep, there are lots of knives that are somewhere in-between and difficult to classify.
-Bob
If the curvature of the top edge of the blade is outward it's a drop-point. If the curvature is inward it's a clip-point. Things get tricky with compound shapes and straight drops, though.
--Bob Q
I once read that "clip point" describes the appearance that the forward top portion of the blade appears to have an arc of steel "clipped" out of it. Sounds like a good description to me.
AG Russel's site uses this pic of their featherweight folder to illustrate it.
Here's my definition, and it usually fits the bill.
IF the knife curves and there is a false edge back OR if the false edge is straight, the knife is usually considered a clip point. IF the back edge is curved forward, it is a spear point.
