- Feb 28, 2011
Ambush Knives Alpha is probably the closest I can think of. Good luck!
I have been looking around and haven't found a 6 inch fixed blade made with one of these steels that fits the budget (other than the Master Hunter 3V). If you know of any, please let me know.
I found [Link removed] and this one. They are a bit small for me but they are within the budget and they seem good. Do you have any experience with them?
I'll argue S30v.
Not because I'm in love with it.
That's just what the industry is set up to mass produce to keep the price lower then others. Its just popular.
its available in numerous knives for around $100 to $150 and has noticble performance over vg10, 154cm in edge retention.
3v has less edge retention but doesn't have micro chip issues because it incredibly tough.
The Cold Steel Master Hunter is ground breaking because its driving the cost down on the most premier fixed blade steel for toughness.
It's has a nice distal taper with a fine tip for slicing, carving and skining game with 3V to prevent chipping with bone contact.
Might be too slim for abusive use.
It's too soon for 3V to be the most cost effective. Most options are well into $200.
3V is by far the most perfect steel in my opinion.
Its hold an edge better than S30V, tougher than most carbon steel while have acceptable rust resistance.
Looking at your uses I see cutting wood as one of the things you plan on doing, are we talking about batoning the blade to cut the wood? How are you going about this? Just wondering so we know how much abuse this knife will see.
3v is a great choice.
Personally I find that coatings are of little value, so if that is harder to find, I wouldn't bother too much about it. Use wears most coatings over time, and find that typically I like the blades performance more without it (less friction when cutting). And most coatings exist to help prevent corrosion, which 3v doesn't really have a problem with anyway. Might be easier to find a knife if the coating isn't as much of a "requirement" is all I'm saying. Worth some thought perhaps.
Good luck on the search.
This looks like a perfect knife for me but it is super expensive at more than $250 and also not sold in many stores.
I'm so tempted to get it but I want to save money so I will keep looking for something that fits the budget.
If you look for the plain micarta handle options you can find it for about $225. Still above budget, but I don't know any 3V blades in that size range that are less expensive. Check out knivesshipfree.com and look for the matte micarta handle option.
Wear resistance and edge retention are not the same thing, edge retention is a combination of wear resistance, toughness, and corrosion resistance. Hardness and toughness are also not the same thing and are usually opposites. For example 3v has twice the toughness at 58rc as it does at 62rc. I hope I haven't made things even more confusingI think the best steel that money can buy, theoretically, is S110V. It is basically S90V but with better corrosion resistance.
But you can get comparable quality with 3V at a much lower cost.
I saw a few abuse videos on YouTube of 3V and it is honestly very impressive. Tougher than anything I have seen (I am not very experienced though).
The great thing about it is that it is somewhat affordable. I don't think you can get better quality for the price.
From my research yesterday, I found out that there are basically 4 categories to measure how good a steel is:
3V excels at 1 and 2. It is very good at 3 and with little care this is not a problem at all. It is relatively good at 4, given what you get for the money and hopefully it get cheaper at it becomes more popular.
- wear resistance/edge retention
- hardness/toughness
- corrosion resistance
- cost
Wear resistance and edge retention are not the same thing, edge retention is a combination of wear resistance, toughness, and corrosion resistance. Hardness and toughness are also not the same thing and are usually opposites. For example 3v has twice the toughness at 58rc as it does at 62rc. I hope I haven't made things even more confusing. Another company that makes 3v knives in your budget is Survive! Knives.
I am thinking about waiting a little longer until 3V becomes more popular and affordable but I am not sure if I can do it.
