- May 2, 2013
The tanto design is primarily used for added strength for penetration. Thats why the are more tactical, it is a thrusting weapon. Surely they are used for more, but thats the idea behind it...
I have thought about that, but I am not fully convinced that a serrated edge is so superior in going through, say, a denim cloth. I have read that a serrated edge can get stuck on fabric easier.but having a fully serrated edge is...
It is a matter of getting used to the shape of the blade to make the most of it, i find that the secondary edge near the tip is great when opening boxes etc. or whenever you need more control over the tip of the blade...and others have already mentioned the piercing and strong tip...my CS Tanto Lite mostly stays in the kitchen...
If you don't already have a tanto / american style, try one out!! CS Tanto Lite (Krupps 4116) can often be found for around $30, or the Kobun (Aus8a) (comes with a very usable sheath) for under $50...
I get the impression you like tanto blades. Very nice.
All right. It is either the new Code 4 tanto or the Voyager large tanto. Leaning towards the Code 4 because of slimness and overall looks. Any points for Voyager that I should take into consideration before I pull the trigger? Voyager is larger and therefore less pocketable, but slightly cheaper.
It's primarily for martial use - the secondary point makes for a highly effective snap cut, pierces while cutting during a slashing stroke, and the primary tip is very strong due to spinal reinforcement. It's also very good at piercing.
Some will tell you that the tip is stronger, Not really, It depends on the thickness of the spine at the tip and a few other factors of blade geometry.
The Tanto is a amercan invention, it showed up on the knife market about 25-30 years ago. That tip was on Japanese swords and pole arms prior to that, but not on the Tanto which translates to women's knife I am told.
In terms of practicality and legality -- I would dissuade you from seeking a knife as your first(?) option for self-defense.To say the truth, the reason I took this up is that I am searching a knife for "martial applications". Things going south where I live and so on.
tanto is the least useful blade/tip profile of them all. I have many knives and not a single tanto
