Update and Review:
http://www.knivesofalaska.com/store.asp?c=42
I got the set from Knives of Alaska. It is a set with a knife called the Whitetail Hunter and a small caping knife, the Bear Cub I think. This season they were along for multiple big game kills, as well as bird hunting and fishing. Most notably, my wife and I took 3 antelope, 2 deer, and 4 elk.
I also regularily use in the field:
Buck 691 (440HC?)
Benchmade skinner in D2
Browning White River Skinner (440C)
Buck 110
Leatherman
I have used this knife set now quite a bit, and think that I've given them a fair shake. I feel inclined to provide a review. Sadly, I've been very disappointed by this product, at most every turn. Please forgive me, as I am not a knife buff and don't know much about various alloys and the tendencies of each one, so bear with me.
Originally I didn't like the KOA knives b/c of the poor fit and finish of the product. However, I use knives as tools, and can live with a poor fit. However, this knife set is pretty bad. Besides my original gripe of having the scales poorly fitted (about 1/16" off from where they belong), with the mold tabs still attached, the metal finish on the caper is boiled (like paint over rust on a vehicle) and streaked. Is there some sort of laquer finish? It looks like silver paint. The defect is only around the bear picture, about an inch long. It does not flake or change. This issue is not a big deal to me, just further indication of poor workmanship. The scales are not loose. The Whitetail Hunter has no such finish problem.
I cannot get the Bear Cub to sharpen. I've sharpened alot of knives, and sometimes it takes me awhile to get the edge the way I like. This is not the problem. I just can't get it to take an edge. This is a knife that I need to be able to get sharp like a razor to be very functional. Big disappointment.
The WH took some time to get where I wanted it. It does sharpen up pretty nicely, but not like a Buck knife. My other knife in D2 is hard to get very sharp, too. They act about the same. As far as the edge goes, I would like it to stay sharp proportionally to how difficult it is to get sharp. I will not buy another knife in D2, as I just seem to spend alot more time sharpening than I get in extended cut time. I came to this conclusion while skinning, quartering, and de-boning the frame on 4 elk in one day. I used several knives in conjunction. I can use a steel to touch up my Buck 691 and have it cutting great again in moments. It takes alot more with the D2, but it doesn't seem to last that much longer. In fact, it never cuts as well to start, but seems to be at that semi-sharp stage for quite awhile. It does take a long time to really dull. I was hoping the guthook would work better than on the Buck, but it clogs about as quickly. A guthook was one of my criteria in a knife that led me to KOA. Originally the wife bought me their Light Hunter. I returned it, but was impressed with the guthook. However, it was built like a hatchet--heavy and very thick, right down to the edge. I have no idea why they call it a "Light" Hunter. The Whitetail hunter on the other hand is quite thin and very light. I like that for all of the elevation I hike while elk hunting. I also like the option to hold the knife forward for better grip and leverage, but I'm not sure it is worth giving up an inch of cutting edge. The legth of the blade helps in reaching far enough to cut around the pooper in the pelvis region of an elk. The V notches on the back of the blade, for thumb traction, are unfortunately small and close. They give great grip, but are impossible to clean. Mine have rust in them, even after a concerted effort to clean out crud. It is a poor design.
Sadly, even the sheath is lacking. It seemed actually to be a high point, nicely built and durable. However, the gut hook of the WH hangs up on a flap of leather and sometimes you have to really maneuver and pull the knife in a less-than-safe manner.
I will not buy KOA again. There just is not very much I like about these knives. I am very disappointed. I will also never buy for a guthook. I overlooked so many knives to try to get a guthook, and ended up making a compromise. I will simply buy a separate guthook, as I do like the speed of using one. Simple solution, but I had overlooked it.
I hope that I don't offend any KOA fans with my review, this is just what I found. I am trying to be as fair as possible, but am really unhappy with this knife set. As I said, I am a hunter and knife user, but not an afficianado. I'm not an expert, but my hunting buddies often come to me for help in sharpening knives, as some have noticed mine are always very sharp. Generally I know what works for me and what does not. I have definately learned from this experience, though.
