- Aug 19, 2000
Yep, the eyeballing method always works for me. When working with antlers and stag crown sticks, you have to work with what nature provides and design the blade and tang around the stag or antler. It may take me half a day to get it just right by holding the antler/stag in my hand and getting the gripping point all figured out. Then I'll trim it close to length on both ends on the bandsaw and from there clamp it in the vice and use a file to get the flats 'close enough' to the angle I'm looking for. I cheat and use scrap leather shims to take up any slack or irregualrities during the glue-up. Mike Williams teaches a simple but brilliant method for following the curve in the stag with a hidden through-tang. It calls for making a 'wiggle' joint in the tightest part of the curve and drilling from both ends to meet at the wiggle joint area. You use all-thread and a cut down union nut for that part. Cut a slot in each end of the union nut and file the all-thread connecting pieces flat to slide inside both ends of the slotted nut. Then drill and rivet the all-thread to the union nut. Hog out the area where the wiggle joint will be so you can slide this whole mess down into the stag once you're ready to 'fit up' the blade/tang to the stag. Clear as mud? The advantage to this type of rig is that if you leave the wiggle joint sloppy enough the butt cap has some room for adjusting itself and getting the right angle and you don't have to fight so much with the flush butt cap end. Kind of hard to describe in 100 words or less.
