- Jul 19, 2011
Sticking with math and geometry, if you decrease the inclusive angle of the flat edge to 45 deg, the convex edge will be outside the flat near the edge.
It's an exaggerated image to make the difference more visible. The convex also has the same thick angle, but that angle then reduces the farther back from the edge you get.
The convex edge has no angle. It's an arc.
Out of curiosity, where do chisel grinds (like the ones on Emerson knives) fall with respect to toughness?
The starting point of the radius, the size of the radius, and the angle of the arc can be measured, but you can't compare it to the linear angle of a flat edge.
In theory it's no different than double bevels of equal angle. In reality, the asymmetry tends to cause unequal strain on the edge and makes it more prone towards rolling the apex.
The more steel behind the edge the tougher it is, so slab flat grind with a convex, moran, edge is toughest, given any one steel.
Actually, you can. Even cursory research will show this to be the case. You just use the tangents at the intersection.
You and I go through this every time, don't we?
A straight line and a curved line are not the same thing.
I can understand why a lot of folks might think that it's not measurable, but it's as simple a matter as Googling "angle at intersection of curves" and you get about 8,610,000 results on the subject.![]()
Claiming you can measure the included angle of a convex edge is like saying you can measure 1 side of a sphere.
