What kind of glue to use?
Was just wondering on what's an easy to work with glue for synthetic handles that also holds well.
i tried gorilla glue--just cause i heard it was pretty good in the glue wars. i didnt like the fact the in foamed up like crazy when it dried, i had to take 10 minutes to sand off the foam before hiiting the scales--marakz--but so far its working well
if you mix gorilla glue with something else (works for liquid nails, but I dunno bout epoxy) then you get really small bubles. it expands a little wich can be good, but the buble are really small so they are much stronger, and less of a pain.
The Gorilla glue should be clamped down really tightly to avoid bubbles, it's made to use thin. The foam that comes out can pretty easily be cleaned up with a razor. Just scrape it from the tang. It is very good glue.
