- Aug 27, 2008
I've always been taught to use a circular motion while sharpening knives on a benchstone. Is this right, or should I be using exclusively edge-leading or edge-trailing strokes? Does it matter?
There really is no kind of agreement on this. The best answer I can give is, do what works for you. Personally, I have tried all of the techniques you have mentioned, and get good results with all of them. It all really comes down to learning what is happening at the edge when you sharpen, and how to get the edge to do what you want, regardless of circuler, leading, or trailing.
Confused yet?![]()
Confused yet?![]()
No slicing motion is needed, when you place your blade on the stone and begin to push forward keep the handle at 90 degrees to the stone and just lift the handle of the knife. This lifting motion will correctly follow the angle and curve of the blade.
When you lift there is also one more motion that takes place and that's a roll, the best way to see this is by placing your knife on the stone and without moving it down the stone lift the handle. If you open you hand and lay it under the knife so just the weight of the blade is on the stone you will be able to feel it better.
I agree. Do you notice a variation of the sharpening angle when using a system like the Edgepro one (stone turning around an axis, edge being tangent to the circle)? Theoretically when the stone moves away from the clamp the angle is reduced. Is it noticeable for a blade, say 6 inches long?
dantzk.
Do you notice a variation of the sharpening angle when using a system like the Edgepro one (stone turning around an axis, edge being tangent to the circle)? Theoretically when the stone moves away from the clamp the angle is reduced. Is it noticeable for a blade, say 6 inches long?--dantzk.
No, because on the EP, the blade is not clamped, you move it back and forth to keep it more in line with the arm. If it is clamped, then you would be correct. cbw
That's the easy stuff though, the main problem that many seem to have with freehand is keeping the correct bevel angle for the curve of the knife. Many were taught the slice method and while it gets close its still not correct. No slicing motion is needed, when you place your blade on the stone and begin to push forward keep the handle at 90 degrees to the stone and just lift the handle of the knife. This lifting motion will correctly follow the angle and curve of the blade.
So you're saying that it's better to lift the butt of the knife instead of keeping the tangent of the edge perpendicular to the stone? How do you figure that?
Even though it does not have a clamp this does not mean that it is okay to move the blade while sharpening. If you move the blade the angle of your bevel will change across the length of the blade.
We have to determine what cross-section we're analyzing, first. I would posit that the meaningful one is perpendicular to the edge of the blade at any given point. Agreed?Because it follows the angle and curve of the blade in a more correct path. The angle you sharpen at does not stay the same if the blade has a curve in it.
That's not how the EP works. Moving the blade keeps it more in line with the arm, which minimizes the angle change. So the arm doesn't have to swing out to cover the entire blade.
cbw
Please do explain then.
