Thank you, that's better and less insulting.
I still, and its MY opinion that its not the be all end all of sharpening tools...
I apologize if my post was insulting to you. I didn't mean it that way. I was just trying to convey that you had an inaccurate, quite frankly, wrong perception of how to use the EP... probably based on the video you watched... and there's a bit more to it. But I follow and read a lot of your posts... you obviously have a lot of knowledge about sharpening. So if I came across that you don't know about sharpening, that wasn't my intent.
I never said, and wouldn't say, that the EP is the "be all end all" of sharpening. Sharpening is a bit of a hobby for me, and because of that I have and use a variety of methods to sharpen. All have their pros and cons, but I've come to the conclusion, no great surprise here, that what you use is not near as important as how you use it. Murray Carter puts it, in his video, at: 99% skill, 1% equipment. Maybe a bit overexaggerated, but it proves the point. I would bet that, based on the results you get with what you use now, you could probably take an EdgePro, a belt sander, paper wheels, or even a coarse/fine SiC stone and put a pretty impressive edge on it.... because it's based more on your skill level. Probably not "more".... almost entirely. I found it interesting, in my personal experience, that when I first started sharpening, I could put a better edge on with some methods than others, but that as my skill and knowledge increased, my results across the board seemed to even out. (Probably not as good as if I had just picked one way and stuck to it.....)
The rest of your post is kinda meaningless... it's subjective. If one: way, method, type of edge, type of grind etc. was ever proven to be better than all the others... everyone would sharpen the same way. Again, it all relates to skill level and this kind of returns to the OP. If a person uses a certain method to sharpen... practices and refines it, the end result will be a sharp edge. Put Ben Dale with an EP, Mike Stewart with a belt grinder, you (based on your hair whittling edges) with a set of diamond stones, Dave Martell and his waterstones, and Murray Carter with a brick and cardboard
in the same room... and they all would turn out very different, but pretty impressive edges. So I tend to avoid the 'X' type of edge sucks... because I know, from what other pros get, and my personal experience using a variety of stuff, that again it's more skill, and I will add - knowledge of what makes a knife sharp, related. I also avoid the... one method is better... you're a good example. A lot of people think that diamonds don't put a very good edge on a knife... your posts clearly prove the opposite. Many say, for example in the "Razor Edge Book of Sharpening" that you can't put as good an edge on a knife freehand as you can with a guide, but YouTube, the forums, and even my own experience says this isn't so... especially on a practical level.
I do know that Dave did a recent video chat, where he stated that the EP was the only angle guided system he would consider... and that it worked for what it was. But I also know that in general, he doesn't advocate their use... and specifically not for Japanese knives, which is what he specializes in.
cbw
