- Oct 27, 2006
If I were to want to install a pocket clip on a Case Trapperlock that doesn't already have one, what kind of tap will I need to tap the holes for the screws? Plug tap, taper tap, etc.?
Bagger, yes sir that makes sense and I appreciate you taking the time to explain it.
I won't be able to drill through a Trapperlock, or even fully halfway through, so it looks like a bottoming tap is my only chance I guess.
Lieblad, which kind do I need?
I'd really like to get a clip on my kirinite trapperlock. Actually, as much as I hate the thought of doing it, I'll bet I could simply drill the holes and use JB Weld to glue them in there. Hmmm... Whatcha think?
Since I want it on the pivot end, I guess I'd better just leave well enough alone then and not mess with any of it.
However, I didn't realize that you could take a slip joint knife apart without completely destroying it, so that's got me intrigued.
I can't
Probably you can't
Skilled slip joint makers can
