what kind of thermocouple??
what is the easiest thermocouple to use for inside a forge? where does it go, and does it hook up to your multimeter? where do you get it? thanks
There are different types of TC's, depending on your need. Inside a forge you will want to put your thermocouple inside a thermowell, both to protect it and give you a more consistent readout. Thermocouples read at there tip, not along their length.
The tech dept at Omega is good about working with you.
http://www.omega.com/prodinfo/images/Junctions.gif
Fred
For our application, Type K is the best suited, and most economical. (Type R and S have a combination of platinum/platinum rhodium that is very, very expensive and have a range of 0 to 3100 degF.)
Most multimeters cannot read T/C inputs. Only certain digital multimeters have the option of a thermocouple input. Thermouples have an output of microvolts (millionths of a volt).
A relatively inexpensive controller can be had at the websites mentioned in the above posts and that is probably your best bet.
Craig
This is the thermocouple you want
http://auberins.com/index.php?main_page=product_info&cPath=3&products_id=39
This is the pid if you want simple and to just read temp. It can also control a SSR if you wanted to contro electricity for a oven or say a valve for fuel supply.
http://auberins.com/index.php?main_page=product_info&cPath=1&products_id=14
This is the SSR you want for a electric oven.
http://auberins.com/index.php?main_page=product_info&cPath=2&products_id=30
To read temp you would just connect 110v to the pid and the thermocouple to the pid. The pid comes with directions. If you used the sample wireing diagram and never hooked in a SSR as it shows you would be reading temps as soon as you plugged it in. Would't even have to program. It comes programed for type K. Get it and I will walk you thru on the phone if nessecary. I have two of them and unlimited long distance.
