- Mar 15, 2010
No need for a big "survival" knife...
Mainly get yourself a good axe for felling trees with, and a good saw to saw it into more manageable pieces ... Then use the axe carefully, and split em for fire wood... no need to baton...
Get yourself a very good folder .. such as an Xm-18.. or strider to sit in your pocket for any tasks around the camp.. like food prep an those types of edc tasks...
Depending on how you intend to start your fires.. you can use ur folder to make some fuzzsticks.. or whatever the case may be...
axes will chop and split firewood for a LONG LONG time.. without needing to be touched up on the edge that is...
large fixed blade will easily need to be touched up after a good week of use out in the wild...
This is one of the biggest differences ... not to mention a lot less calories are used while using an axe as the job gets done in about 1/4th of the time once you get some experience with an axe...
Some will like to match the felling axe... with a much smaller hatchet... for the delimbing process, along with to help with processing any game, and what not... that is completely up to you...
Go out and see what your actual needs are... don't get sold by others...
at the end of the day.. if your sold on a large fixed blade to do the job... go for it.... since its only a recreational weekend of camping or what not... it's not really going to matter...
however if you were attempting a months stay out in the wild.. you'd be quite screwed if you batoned your blade right into the ground, which is bound to chip/roll or even snap ur edge..
One guy on youtube was battoning through a tree with the heavy bowie ka-bar... he was about half way through and the entire blade snapped into pieces... the company replaced it, but why take that risk? ..
later!
later!
